it it worth running a shorter duration solid flat tappet?
Comparing two off the shelf grinds as an example:
Comp 270 H magnum
Comp 270 S magnum
For a motor example, typical back yard 350
Comp 270 H magnum
Comp 270 S magnum
Re: it it worth running a shorter duration solid flat tappet?
for the typical backyard built 350 where a guy just stabs the cam in and doesnt bother to degree it, may as well run the hydraulic.
Ok not THAT backyard maybe . Just a typical build
I can't see a benefit, they are both 224 @.050 and 135 @.200 with a .313 lobe lift. I guess it is just a matter of do you want to do valve lash on occasion.
I guess it depends on what one considers typical, for me that would not be a solid flat tappet motor. For me if a hyd flat doesn't fit the bill the I typically go solid roller. Everything in between seems to be a more costly compromise. My cross over point would probably be in the mid to upper 280's seat duration.
Go with the hydraulic, cheaper (lifters) no valve adjustments and no worries about pressed in rocker studs pulling out. (Not certain that would actually happen)
I don't think you can compare a hydraulic and solid, "apples to apples", in terms of duration.
They measure advertised duration at different lifts and I think that affects everything. Bottom line is to get a similar rpm range you generally need a solid to have very roughly 8 degrees more duration @ 0.050" compared to a hydraulic. So you might need something like 232 degrees duration @ 0.050 on the solid to have the same rpm range as a 224 @ 0.050" hydraulic.
JMO,
paulie
JMO,
paulie
I believe plovett is correct. I have that comp 270 solid in a 64 chevy with a backyard 350.Runs good with very good throttle response
I'm in this camp as well. I ran the 270S in a 350 in a heavy Blazer with 35" tires. I ported the crappy smog heads and the exhaust ports cleaned up really well. The cool thing about the solid Magnum cams is they have a wide range on lash settings so you can fiddle around with it and see what you like best. Every time I tightened up the intake and loosened the exhaust, I was rewarded with a smoother idle, more vacuum and more butt-dyno power. I think (it's been 15 years) I ended up at something like .016" on the intake and maybe .024" on the exhaust.
I've never run the 270H so I can't compare the two. I just know the 270S ended up being a pretty cool, old-school cam with a bit of a "tuning window."
Correct. Because of the difference in height between the hydraulic ramp of the hydraulic cam, and the lash ramp of the mechanical cam, the mechanical cam needs to be 4-8 degrees longer at .050", to have the same power curveplovett wrote: ↑Mon Jul 08, 2019 6:14 am I don't think you can compare a hydraulic and solid, "apples to apples", in terms of duration.
JMO,
paulie
What year 350 ( compression ?) and what rear gears are or will be in the car?
I have a lot of time in on the Isky 270H mega Cam in a 9.2 to 400 motor and with everything the same but with only 8.5 comp and 2.73 gears the car was pretty soft below 2300 rpm with a TB350.
Where talking a 3650 lb car here.
- Stan Weiss
Gary,
If these are the two lobes. Then the difference shows up when looking ATDC values.
5201 270-4 224 135 .3130 .069 .057 .470 .501 .532
6017 270-3 224 135 .3120 .064 .054 .468 .499 .530
Do you think there would be any measurable difference in power?Stan Weiss wrote: ↑Mon Jul 08, 2019 12:55 pmGary,
It's out of a 1974 Chevy C50 truck. 175hp factory rating.
Seems like a dished piston 882 headed motor.
Flat top pistons
Import heads either Flotek or ProMaxx (buying bare)
Cam
RPM Air Gap or equivalent
Carb
Trans either a TH350 or a Muncie M20
3:1 gears in a 9"
Going in a longbed 58 Chevy Apache that is manual steering, brakes
Note I am totally open to cam suggestions. I figured if a solid will give me a meatier power band it would be worth it
Flat top pistons
Cam
Carb
3:1 gears in a 9"
The mechanical cam would peak about 200 rpm sooner.GARY C wrote: ↑Mon Jul 08, 2019 1:28 pmDo you think there would be any measurable difference in power?Stan Weiss wrote: ↑Mon Jul 08, 2019 12:55 pmGary,
