It seems you have a different engine configuration for almost every different occasion and the need for one combination to be good at everything but, not great at all situations is not there.blackflag wrote: ↑Sat Jul 20, 2019 6:16 pm These are engines that get run quite often. I love trying different combinations. We have a 4” stroke 3.625” bore 360 that we run on pavement. It’s very capable of winning but has a rookie driver. The big bore short stroke engines are proven winners and have been our main 360s on pavement and some dirt since 2008. They will go when you can keep the pipes lit. They don’t peddle good in the dry slick. They are like a high strung two stroke. The 3.915” engine is complete and ready to dyno. All engines have 23 degree heads. I’m going to dyno 5 engines when time permits.
The common 23 degree headed 360 Chevy sprint engine built around here has a 4.00" to 4.004" bore with a 3.562" stroke using a 6" rod length.
By rules, these are cast iron headed engines using production replacement blocks.
