ptuomov wrote: ↑Thu Jul 18, 2019 4:36 am A novice question: Isn't the change in the valve size by far the most important change here in terms of the camshaft? I'm just thinking out loud that the the rod ratio change would have a smaller effect and the change in the bore vs. stroke (keeping the displacement the same) an even smaller effect. Curious about the magnitudes and what issue to focus on.
5528 - 4.500 bore x 4.15 stroke, 6.76 rod, 1.628 RR
At 14 deg ATC:
piston position.....2.04mm
piston vel...........10.43m/s
piston accel........2633G
Maximum piston velocity...34.66 m/s
For the two engine examples shown above, the areas under the flow curves are:26 - 4.380 bore x 4.375 stroke, 7.100 rod, 1.622 RR
At 14 deg ATC:
piston position.....2.15mm
piston vel...........11.0m/s
piston accel........2778G
Maximum piston velocity...36.55 m/s
32,031 CFM and 32,061 CFM respectively. Given the same valves and cam, they flow virtually the same CFM.
The small changes in stroke are offset by the small change in rod length. There would be no need to change valve curtain area, valves, lift, or cam lobe shape.
