Camshaft changes or not with stroke increased.
Walter R. Malik
Re: Camshaft changes or not with stroke increased.
Post by Walter R. Malik »
blackflag wrote: Sat Jul 20, 2019 6:16 pm These are engines that get run quite often. I love trying different combinations. We have a 4” stroke 3.625” bore 360 that we run on pavement. It’s very capable of winning but has a rookie driver. The big bore short stroke engines are proven winners and have been our main 360s on pavement and some dirt since 2008. They will go when you can keep the pipes lit. They don’t peddle good in the dry slick. They are like a high strung two stroke. The 3.915” engine is complete and ready to dyno. All engines have 23 degree heads. I’m going to dyno 5 engines when time permits.
It seems you have a different engine configuration for almost every different occasion and the need for one combination to be good at everything but, not great at all situations is not there.
The common 23 degree headed 360 Chevy sprint engine built around here has a 4.00" to 4.004" bore with a 3.562" stroke using a 6" rod length.
By rules, these are cast iron headed engines using production replacement blocks.
David Redszus
Post by David Redszus »
If we know the torque peak rpm, we now have the piston air demand.
All we need now is valve size, max lift, and duration to determine valve curtain area. Followed by port CSA.
n2xlr8n
Post by n2xlr8n »
Great thread. Reminds me of 10-12 years ago.
Thanks, Fellas.
ptuomov
Post by ptuomov »
Here's a practical example.
Suppose that I'm running a 5.0L engine (100mm / 3.937" bore, 78.9mm / 3.106" stroke) that has well-breathing and arguably too big 4-valve heads. It's running really well with these flat-bucket hydraulic cams:
IN 0.414 lift 260 deg. @ .006 lash, 217 deg @ .050
EX 0.370 lift 246 deg @ .006 lash, 208 deg. @ .050
LSA 114, IN LCA 120.5, EX LCA 107.5
Peak power is there at the 6200-6400 rpm range. Nice street engine for a street car, passing smog, idling well, and making good power.
Now, suppose that I increase the displacement to 5.4L (keeping the same bore but increasing stroke to 85.9mn / 3.382") while keeping the intake, heads, valves, exhaust, etc. all the same.
How should I change the camshaft to make the engine "feel" the same as before, just more powerful?
Put Search Keywords Here
CamKing
Post by CamKing »
ptuomov wrote: Mon Jul 22, 2019 4:35 pm Here's a practical example.
You would need to go to 268/254 @.006"
Can't calculate lift or Lobe centerlines without more info.
ptuomov
Post by ptuomov »
CamKing wrote: Tue Jul 23, 2019 12:06 pm
Interesting. Even a small increase in stroke and displacement seems to increase the recommended seat timing quite a bit.
Some additional info:
Dual 37mm intake valves.
The approximate cross-sectional areas for the stock 37mm valve intake port are:
- Intake port at the flange 1700 mm2
- Divided port where the divider wall starts [2*750, 2*850] = [1500, 1700] mm2
- Divided port where the valve guide is protruding, adjusted for the valve stems [2*(871 - 33) = 2* 838 = 1676 mm2
- At the valve seat ring 2*(750-33) = 1434 mm2
Something like a dual plane intake with 40cm and 30cm runners lengths from the trumpet opening to intake valve.
The bare head with a bellmouth flows about 300 CFM @28" at 12mm intake lift. From memory, the flow drops below 250 CFM in the worst cylinder (#5) when the intake is on.
Dual 33mm exhaust valves. Exhaust port circular 40mm CSA 1257mm2. Throat 28.4mm combined CSA 1267mm2.
Walter R. Malik
ptuomov wrote: Tue Jul 23, 2019 12:34 pm
CamKing wrote: Tue Jul 23, 2019 12:06 pm You would need to go to 268/254 @.006"
Sometimes, 4.6L to 5.4L having the same bore is not just a SMALL increase in stroke ... almost 5/8" with Ford Mod Motors having their small bore.
Last edited by Walter R. Malik on Tue Jul 23, 2019 3:42 pm, edited 1 time in total.
ptuomov
Post by ptuomov »
Walter R. Malik wrote: Tue Jul 23, 2019 3:36 pm
4.6L to 5.4L having the same bore is not just a SMALL increase in stroke ... almost 5/8" with Ford Mod Motors.
I'm adding 7mm or 0.2756" to go from 5.0L to 5.4L. That's less than 9% more stroke and displaecment.
Walter R. Malik
ptuomov wrote: Tue Jul 23, 2019 3:40 pm
Regardless of percentage ... most people would call a .275" stroke increase more than small. I guess you consider it small.
CamKing
Post by CamKing »
I'm adding 7mm or 0.2756" to go from 5.0L to 5.4L. That's less than 9% more stroke and displacment.
Yes, and only requires about a 3% increase in duration.
ptuomov
Post by ptuomov »
Walter R. Malik wrote: Tue Jul 23, 2019 3:47 pm
I'm adding 7mm or 0.2756" to go from 5.0L to 5.4L. That's less than 9% more stroke and displacement.
It's probably just me anchoring to my context. The most common stroker crankshaft for the engine in question has 95.25mm / 3.75" stroke. If that's combined with 104mm overbore, it gets one to about 6.5L from the original 5.0L, which is 30% change.
