Jaguar 4.2 E type lip rear main seal conversion?
KnightEngines
Post by KnightEngines »
Got a Jag E type 4.2 in, owner wants to convert to a 2 piece lip rear main seal.
I figure I can grind the seal area on the crank & find a seal to fit, but if anyone has done this before it'd make life easier knowing exactly what to do & get!
af2
Re: Jaguar 4.2 E type lip rear main seal conversion?
Post by af2 »
I don't know if this helps but this guy is a true gentleman to talk to and does a lot of one off stuff.
https://www.facebook.com/cedarmachine/
GURU is only a name.
Geoff2
Post by Geoff2 »
It would help if you posted dimensions. Crank OD, housing OD & width.
gn69z28
Post by gn69z28 »
Don't hold me to it but I ground the seal area of one of these cranks for this reason several years ago and and I think there is an adapter that goes in the block to hold the seal. I don't remember what seal was used,I want to say small block Chevy but I've only seen it done once so my memory isn't that great.
apm
Post by apm »
We fit seal conversion kits to Jags all the time for one of our customers, I'll have to check the brand and let you know, there is a holder that bolts to the block and it uses a small block chev rear seal, they give you a drawing for modifying the seal track on the crank , really easy
