Bush aluminum rod
Bush aluminum rod
Want to know has anyone bushed an aluminum rod, with success? I know it can be done, but will it last in a hi-po environment.
Re: Bush aluminum rod
Yes
Remove bushing and measure the small end of rod ID then call PPPC and get a replacement based on your size requirements.
You need the pin end to be round to start with so if thats not stretched out of shape then get a set of replacements from the
rod manufacture and do them all.
These rods have never been bushed, need bushings to size for different pins. Never seen aluminum rod bushed before.
"Never seen aluminum rod bushed before."
1970s hi-tech 2 stroke -
https://i.ebayimg.com/images/g/2qcAAOSw ... -l1600.jpg
Some list members probably have some of these lying around.
British motorcycle ( Triumph)
https://cdn.frooition.com/150244/images ... 9525_1.jpg
Yes. [cough]British engineering[/cough] And Pauter once made aftermarket rods that way...Tom Walker wrote: ↑Sat Jul 20, 2019 9:56 amIs that a steel cap on an aluminum rod in the last picture?
I guess why not? There are engines with iron/steel main caps and aluminum blocks and vice-versa..dwilliams wrote: ↑Sat Jul 20, 2019 12:56 pmYes. [cough]British engineering[/cough] And Pauter once made aftermarket rods that way...Tom Walker wrote: ↑Sat Jul 20, 2019 9:56 amIs that a steel cap on an aluminum rod in the last picture?
