Cam Check
lyonsperf
Cam Check
Post by lyonsperf »
Where can I send an old Crane mechanical cam, SBC, to get checked out for wear, straightened and polished for a new set of lifters?
I used this cam many years ago, swapped it out for a milder grind but now want to go back to it.
Dealer for Undercover Innovations, Metco,Dynamic,Fragola and many other American Made products!
Check my site http://www.lyonsperformance.com
mag2555
Re: Cam Check
Post by mag2555 »
If it's a cast iron core Cam I have no idea how you streighten that!
rebelyell
Re: Cam Check
Post by rebelyell »
Seems any decent auto machine shop that grinds cranks should be able to measure straightness, lift and journal concentricity; and polish.
Re: Cam Check
Post by F-BIRD'88 »
Is this camshaft a flat tappet cam or a roller cam?
Dave Koehler
Re: Cam Check
Post by Dave Koehler »
I bet it will be easier, quicker and cheaper to purchase a modern version of that cam.
Old SBC Flat tappet cam
Straightness check can be done on a flat surface with a light or feeler gauges under the journals.
Basic full lift wear can be comparatively measured with a micrometer.
I really doubt you will want more detailed measurements.
That may cause major disillusionment. :)
Polishing a used flat tappet...meh.
If it is to remove rust it is likely already toast.
lyonsperf
Re: Cam Check
Post by lyonsperf »
Thanks everybody for the replys.
Its a old Crane Commander 113841. The new 113841 has completely different grind specs.
I was told many years ago that you needed to polish the lobes to get new lifters to mate to them.
Krooser
Re: Cam Check
Post by Krooser »
mag2555 wrote: Mon Jul 22, 2019 5:55 am If it's a cast iron core Cam I have no idea how you streighten that!
The new cam you buy has been straightend by the core supplier and again by the grinder....been doing it that way forever.
Re: Cam Check
Post by F-BIRD'88 »
What is the cam grind number on the end?
Or on the old cam card....
To see if this cam exists under a new catalog part number now..
Weigh that price to the price of inspecting, servicing your old cam beyond what you can do your self...
If there is any lobe wear showing now it is not worth trying to polish it.
Jones Cams and most others are capable of analysing inspecting your cam but is it cost effective if that grind does exist as a catalog grind now and or VS just getting Crane Cams grinding you a new one (custom grind)
They have the masters....
Did you contact Crane Cams?
Did you do any self measurement/inspection?
Say on V blocks or in a block...?
lyonsperf
Re: Cam Check
Post by lyonsperf »
Yes I have the cam card.
The grind is no longer listed.
I may just have a new cam ground using the specs.
Pete1
Re: Cam Check
Post by Pete1 »
You have several alternatives.
1 - Buy a new cam with similar specs from Mike Jones.
2 - Buy a new cam from Mike with a modern grind that will do what you want it to.
3 - Have your core reground to something Mike says you need for your application.. (assuming the core is salvageable)
DO NOT try using it by just polishing the lobes, even with new lifters. You might get away with that on a stock or very mild cam, but it is a recipe for disaster on a performance grind.
Remember, a lost lobe or lifter means a COMPLETE teardown/rebuild, right down to acid stripping the block.
As for straightening cams, cast iron cams are straightened by peening. NEVER in a press.
Steel cams can be straightened by peening, localized heating and cooling or in a press.
PRH
Re: Cam Check
Post by PRH »
If you just “have to have” that same exact grind, I’m sure Crane still has the masters and could grind one for you.
That was always a pet peave of mine with Crane.
They’d come up with some new grind, then assign a preexisting part number to it.
I never understood that logic.
It’s not like they ran out of numbers.
They’ve done it with some valve springs as well.
Different springs, different pressures and rates....... same part number.
lyonsperf
Re: Cam Check
Post by lyonsperf »
When did they move to MS?
Website doesn't show my p/n as avilable even in the new grind.
Re: Cam Check
Post by F-BIRD'88 »
Post the specs of the cam card you have.
And the grind number.
And what ever is stamped on the end of your camshaft.
midnightbluS10
Re: Cam Check
Post by midnightbluS10 »
They sell em everywhere if this is the cam you're talking about that you can't find
https://www.summitracing.com/parts/crn-113841
Its had those same specs since at least 2005.
If that's not the correct PN that I've posted, please disregard this post.
JC -
Krooser
Re: Cam Check
Post by Krooser »
lyonsperf wrote: Mon Jul 22, 2019 9:47 pm When did they move to MS?
Must be when Comp bought them...
