HELP....conversion needed..
I have 2 Yanmar 3JH3 diesel engines to rebuild. I've been giving the factory manual for specs. Problem is the I can't find a conversion for the torque specs. An example of what the book gives is Main bearing bolt torque is 10.5--- 11.5 kg.m the only conversion calculator I can find converts it to 23ft lbs. And that's not right based on the size of the bolts and how tight they were. I found torque specs online for the 3JH5 engine and it gives 75ft lbs for the main bolts which seems correct but I'm not sure if the two engines use the same torque specs. I couldn't find anything specific to the engines I have. Thanks for any help.
Re: HELP....conversion needed..
Hey I was just looking-my “inexpensive” KD tools beam type inch pound wrench has newton meters on its scale- it came from the parts store in a pinch because none of my inch pound snap on wrenches covered that little range.....
Might be an inexpensive way to get by——
Jason
Jason
Just go google a torque chart for metric bolts, find torque by bolt size, hardness, and thread pitch, done it many times.gn69z28 wrote: ↑Tue Jul 30, 2019 8:58 am I have 2 Yanmar 3JH3 diesel engines to rebuild. I've been giving the factory manual for specs. Problem is the I can't find a conversion for the torque specs. An example of what the book gives is Main bearing bolt torque is 10.5--- 11.5 kg.m the only conversion calculator I can find converts it to 23ft lbs. And that's not right based on the size of the bolts and how tight they were. I found torque specs online for the 3JH5 engine and it gives 75ft lbs for the main bolts which seems correct but I'm not sure if the two engines use the same torque specs. I couldn't find anything specific to the engines I have. Thanks for any help.
https://www.google.com/url?sa=i&source= ... 7040664540
This converter says 11 kg/m is 79.5 lb/ft. 10.5 kg/m is 75.9 lb/ft
https://www.convertunits.com/from/kg-m/to/lb-ft
The conversion seems simple enough to even do manually. 1 kg/m equals 7.233 lb/ft (2.205 lbs/3.280 ft)
Divide each side by 3.280 to get lbs/ft, which should give you 7.2xxx lb/ft is equal to 1 kg/m
kg•meter is not a well used torque unit especially since a kg is not a force unit (kg is a mass unit).
Basically, a kg needs to be multiplied by gravity, 9.81 meters/second^2, to convert kg to Newtons (N).
A Newton•meter is a standard torque unit in the SI system.
To convert a Newton•meter to lbf•ft (ft•lbf for those folks), simply divide N•m by 1.356.
- midnightbluS10
Wouldn't that get you the same exact result as converting from kg/m to lb/ft, only with a lot more chance of screwing up the math making 2 conversions instead of 1?Rick! wrote: ↑Tue Jul 30, 2019 4:23 pm kg•meter is not a well used torque unit especially since a kg is not a force unit (kg is a mass unit).
Why do 2 conversions when you can convert straight from 1 to the other with much less math? Converting kg to lbs and m to ft isn't that difficult?
JC -
- Stan Weiss
Last I check that is still 2 conversions.midnightbluS10 wrote: ↑Wed Jul 31, 2019 6:36 amWouldn't that get you the same exact result as converting from kg/m to lb/ft, only with a lot more chance of screwing up the math making 2 conversions instead of 1?Rick! wrote: ↑Tue Jul 30, 2019 4:23 pm kg•meter is not a well used torque unit especially since a kg is not a force unit (kg is a mass unit).
Stan
The OP asked for help and got a fish and a loaf of bread thrown at him. All I did was throw him a fishing rod.midnightbluS10 wrote: ↑Wed Jul 31, 2019 6:36 amWouldn't that get you the same exact result as converting from kg/m to lb/ft, only with a lot more chance of screwing up the math making 2 conversions instead of 1?Rick! wrote: ↑Tue Jul 30, 2019 4:23 pm kg•meter is not a well used torque unit especially since a kg is not a force unit (kg is a mass unit).
You can see that he tried to convert kg to lbf using 2.205 lb per kg and that didn't get him where he needed to be.
Sometimes it's better to know how to do simple units conversion, or dimensional analysis, to get from one measurement system to the next.
One could also argue that most modern torque wrenches have both N•m and ft•lbf scales so the only operation necessary is multiplying kg•m
times gravity (9.81, or 10 in a pinch) and then use the scale or button on the torque wrench for N•m so only a single operation is needed.
Here is a link to a units convertor that nearly every engineer I work with, including me, has on their computer.
https://joshmadison.com/convert-for-windows/
To convert KgM to ft lbsgn69z28 wrote: ↑Tue Jul 30, 2019 8:58 am I have 2 Yanmar 3JH3 diesel engines to rebuild. I've been giving the factory manual for specs. Problem is the I can't find a conversion for the torque specs. An example of what the book gives is Main bearing bolt torque is 10.5--- 11.5 kg.m the only conversion calculator I can find converts it to 23ft lbs. And that's not right based on the size of the bolts and how tight they were. I found torque specs online for the 3JH5 engine and it gives 75ft lbs for the main bolts which seems correct but I'm not sure if the two engines use the same torque specs. I couldn't find anything specific to the engines I have. Thanks for any help.
1 KgM = 7.233 ft lbs
- midnightbluS10
That was posted above. Plus a breakdown of how that, number is achieved. Fish and bread? Huh?
I'm not near as smart as you are, David, and even I see that. Convert kg to lbs and meters to feet and you end up with 1kg/m = 2.2 lbs/3.28ft
Not hard to finish from there.
JC -
- midnightbluS10
Then I guess that makes his way 3 conversions.Stan Weiss wrote: ↑Wed Jul 31, 2019 10:39 amLast I check that is still 2 conversions.midnightbluS10 wrote: ↑Wed Jul 31, 2019 6:36 amWouldn't that get you the same exact result as converting from kg/m to lb/ft, only with a lot more chance of screwing up the math making 2 conversions instead of 1?Rick! wrote: ↑Tue Jul 30, 2019 4:23 pm kg•meter is not a well used torque unit especially since a kg is not a force unit (kg is a mass unit).
Stan
JC -
- Stan Weiss
► 11 * 9.81 / 1.356 = 79.5796460177midnightbluS10 wrote: ↑Thu Aug 01, 2019 6:50 pmThen I guess that makes his way 3 conversions.Stan Weiss wrote: ↑Wed Jul 31, 2019 10:39 amLast I check that is still 2 conversions.midnightbluS10 wrote: ↑Wed Jul 31, 2019 6:36 am
Stan
► 11 * 2.2046 * 3.2808 = 79.56136848
Still looks like two conversions for each to me.
Stan
How about:► 11 * 9.81 / 1.356 = 79.5796460177
11 * 7.233 = 79.563
How many conversions is that?
Does anyone remember the correct use of significant digits?
Using ten more decimal places does not make a calculation more accurate.
- Stan Weiss
David,David Redszus wrote: ↑Thu Aug 01, 2019 8:25 pmHow about:► 11 * 9.81 / 1.356 = 79.5796460177
11 * 7.233 = 79.563
I am lazy and just cut and paste the results from a calculator. So what calculator do you use that has that logic?
Stan
