It is not a high rpm design. It is a usable torque design. Does the w on the intake even matter? Take a look how small the intake valve vs. the exhaust valve is. That is for mileage, bigger exhaust valve.englertracing wrote: ↑Fri Aug 02, 2019 5:18 pm I see what you mean now
Would be a shame really...
I'm surprised this isn't a 4 valve motor....
Or even a 4v with some twist like a diesel to promote swirl.
Maybe John will make some "boss" heads if this engine becomes popular.
Pushrod Ford official.
Re: Pushrod Ford official.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
A 4 valve motor will make more torque if it’s. Holt for it, as opposed to rpm. It will always have the potential to have a flatter and wider power curve than a 2 valve head, any day.
Pretty cool, just wonder why (besides packaging or demand for a cheap, simple fleet type engine)?
I don't believe that is true. 4 valvers have better breathing at higher rpm and better torque at higher rpm but at lower rpm the swirl induced by a single inlet valve can make better torque at lower rpm than the more tumble oriented 4 valver. This is not an absolute. More of a guide, now take a 4 valver and twist the ports and size them just right and they will out torque the best 2 valver.hoffman900 wrote: ↑Fri Aug 02, 2019 7:54 pm A 4 valve motor will make more torque if it’s. Holt for it, as opposed to rpm. It will always have the potential to have a flatter and wider power curve than a 2 valve head, any day.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
What exactly would they be trying to prove? They can build a pushrod engine still? Only they have to copy an already proven design to do it?
You mean like how GM dropped the pinch port SBC to copy a Windsor almost exactly, you know heads that make sense, and a camshaft far enough away from the crank to allow real lobes, and a larger Cam core?
So did Ford copy GM's copy of a Windsor?
Or has for always made symmetrical port engines with large Cam cores ford from the crankshaft?
I think its the latter.
Why does everybody claim GM copied Ford with the LS? There's no proof of it. I'm more apt to believe that GM just designed a better engine and this was the result. IMO, it's more likely that they took the best ideas from any/many engines and combined them to design the LS engine. Much moreso than they took a Windsor, copied it, modified a couple of things, and started manufacturing them.
And now Ford is copying a copy of their engine? Lol! You understand how dumb that sounds, right?
That is exactly what I'm talking about.The engineer in above article even mentioning chevies borrowing tec from Windsor. I think with the hubabaloo the ls has created over the years Ford said hey. We'll build a real LS. The boost ready pistons are there for a reason. Im willing to bet Ford had those engines singing far beyond 430hp!! We'll Seeenglertracing wrote: ↑Sat Aug 03, 2019 1:05 amYou mean like how GM dropped the pinch port SBC to copy a Windsor almost exactly, you know heads that make sense, and a camshaft far enough away from the crank to allow real lobes, and a larger Cam core?
You think so? GM and Ford appear to be just filling in a hole in the market with these engines. Somebody that does some towing, doesn't require diesel torque and doesn't want the cost, complexity and related maintenance costs that go with modern diesel's. I bet aftermarket modifications down the road weren't on their list.Steve.k wrote: ↑Sat Aug 03, 2019 9:50 am That is exactly what I'm talking about.The engineer in above article even mentioning chevies borrowing tec from Windsor. I think with the hubabaloo the ls has created over the years Ford said hey. We'll build a real LS. The boost ready pistons are there for a reason. Im willing to bet Ford had those engines singing far beyond 430hp!! We'll See
I hope it takes off in that fashion but I doubt it. Look at Ford's 6.2. Neat engine, next to no aftermarket support/interest.
You hit the nail on the head. It's all about cost of production and in vehicle packaging while making the 6.8L V10 go away.hoffman900 wrote: ↑Fri Aug 02, 2019 7:54 pm A 4 valve motor will make more torque if it’s. Holt for it, as opposed to rpm. It will always have the potential to have a flatter and wider power curve than a 2 valve head, any day.
B F Evans Ford Race Parts
270-278-2376
270-278-2376
Well it could be and nowadays cost is likely paramount. But most hotrodders want a simple design they can work on. The overhead cam engines dont fit that mold even though they are over achievers in their class when you look at hp/cube. This platform will help, single cam, inline valves and cubes. Let the aftermarket begin!
I don't doubt it, if they make enough of them. I'd love to dive into a 7.3L pushrod engine. I'm kinda beyond dropping 25k in an aftermarket-engine.
The way I look at it (in terms of my 6.2L) is the stock engine was designed well enough that I can throw boost at it, add headers / exhaust and a good tune and make >500 whp. That's enough to tempt me to try it in a lighter car.
I personally believe Ford will add Godzilla to the Raptor at some point.
I don't really understand how overhead cams are seen as complicated though. The geometry is fixed - drop the cams in, index, and go. Furthermore, with multiple camshafts, you can adjust the centerlines to whatever it needs to be without buying a butt load of camshafts.Steve.k wrote: ↑Sat Aug 03, 2019 11:27 am Well it could be and nowadays cost is likely paramount. But most hotrodders want a simple design they can work on. The overhead cam engines dont fit that mold even though they are over achievers in their class when you look at hp/cube. This platform will help, single cam, inline valves and cubes. Let the aftermarket begin!
True. Unfortunately Ford's journal size fetish didn't stop at the camshaft though.englertracing wrote: ↑Sat Aug 03, 2019 1:05 am Or has for always made symmetrical port engines with large Cam cores ford from the crankshaft?
I'm told the 7.3L gas engine has 2.5" main journals and 2.0" rod journals.
270-278-2376
270-278-2376
Yes and as ouput goes up you want to eliminate as many variables as possible. Im liking the idea of this engine. How many guys took a junk yard LS and bolt turbo on and go racing??
