I raised the ports they are 1.85 tall and 1.194 wide, it's hard to see in the first photo but the valve cover rails have been notched to accept a trim to fit gasket, hear is what a 1205 would look like on them. The intake is a raised runner cut to fit a standard head as per the picture but it will be raised to match the roof of the now raised port.steve cowan wrote: ↑Wed Aug 14, 2019 4:13 pmGary,GARY C wrote: ↑Mon Aug 12, 2019 11:33 pm A run down on my Rectoval port, I have not cc'ed it because all of the stuff I used to cc has disappeared, not sure how to measure a Rectoval?
Flow is
2-140
3-200
4-244
5-277
6-300
7-303
7.5-305
Air speed from enter through port is 397, ssr apex floor is 418...Where to go from here?
Is this a test head or are you going to use it on a engine?
What size is the port opening 1207 gasket ?? Looks big
600 HP 350 SBC?
Re: 600 HP 350 SBC?
Re: 600 HP 350 SBC?
I have a version you sent me in 2017, I just sent you the original email,(email failed to go through), last time I tried to open it it wanted verification that I no longer have.Stan Weiss wrote: ↑Wed Aug 14, 2019 4:45 pmGary,GARY C wrote: ↑Mon Aug 12, 2019 11:33 pm A run down on my Rectoval port, I have not cc'ed it because all of the stuff I used to cc has disappeared, not sure how to measure a Rectoval?
Flow is
2-140
3-200
4-244
5-277
6-300
7-303
7.5-305
Do you have DV's and my FLOW Program?
You would need port height, port width and what each corners radius is.
The port is 1.85 tall and 1.194 wide but I am not sure on the big top radius corners and the floor is a full oval.
Re: 600 HP 350 SBC?
I’m pretty sure I’ve never had a 200cc sbc intake port go anywhere near 295cfm....... so if you’re are that good, I’d say put them on and run them.GARY C wrote: ↑Wed Aug 14, 2019 8:39 pmMy flow #'s are on a bigger bore, probably 295 on a 4" bore, they are around 200cc.PRH wrote: ↑Wed Aug 14, 2019 4:21 pm It sure “looks” big for only 305cfm.
Well, I don’t mean “only 305cfm”....... but it looks bigger than I’d expect 305cfm to look.
I don’t see much high effort sbc stuff at my shop(I do mostly Mopar stuff), but here’s some numbers from an ootb cnc ported TFS 230cc head(uses a 1206 gasket) .....tested on a 4.00” bore-
Lift———int flow
.100—— 66.6
.200——140.8
.300——211.2
.400——258.0
.500——286.1
.600——290.5
.700——294.3
Here’s what they show...... tested on a 4.155 bore:
- Stan Weiss
Re: 600 HP 350 SBC?
Gary,GARY C wrote: ↑Wed Aug 14, 2019 8:49 pmStan Weiss wrote: ↑Wed Aug 14, 2019 4:45 pmGary,GARY C wrote: ↑Mon Aug 12, 2019 11:33 pm A run down on my Rectoval port, I have not cc'ed it because all of the stuff I used to cc has disappeared, not sure how to measure a Rectoval?
Flow is
2-140
3-200
4-244
5-277
6-300
7-303
7.5-305
I have a new email address. I have sent you an email.
I am going to make an assumption that the bottom of the port is a continuous arc. That means the port width is the diameter and half the port width is the radius.
To double check that lay a straight edge across the port where the epoxy stops on both sides and measure from the middle on the straight edge to the bottom of the port.
1.85 x 1.194 = 2.209 sq in No corner radius
1.85 X 1.194 = 2.056 sq in No top corner radius and .597 for bottom corner radius
Re: 600 HP 350 SBC?
Grumpys and Smokeys books talk about 600hp level 350s ,, late 70s stuff ,, doesn't look difficult ,, Smokeys stock block Indy motor was 675 with a roller cam and mechanical FI , 355 ,, nothing really out there
Re: 600 HP 350 SBC?
Re: 600 HP 350 SBC?
Yes I was guessing they probably under 2.0, the floor will have to come down some when I do the intake, I will probably just have to see where I end up.Stan Weiss wrote: ↑Wed Aug 14, 2019 10:22 pmGary,GARY C wrote: ↑Wed Aug 14, 2019 8:49 pmStan Weiss wrote: ↑Wed Aug 14, 2019 4:45 pm
Gary,
Re: 600 HP 350 SBC?
That's a whole lot of work and probably get it sorta close.Stan Weiss wrote: ↑Wed Aug 14, 2019 10:22 pmGary,GARY C wrote: ↑Wed Aug 14, 2019 8:49 pmStan Weiss wrote: ↑Wed Aug 14, 2019 4:45 pm
Gary,
Best way is with a planimeter. Trace the port or use a soft piece of solder to do the internal shape.
Then lay the solder on a piece of paper and trace the outer area. Then get your handy dandy planimeter and go around the outline stopping where you started
It reads out the exact area for you
I'll post pics and a video on how quick and accurate it is..it's the only way to do real odd shaped ports and get it exact
Re: 600 HP 350 SBC?
gm, that sounds interesting.
Re: 600 HP 350 SBC?
Jenkins did it but he had a team of pros sweated every detail spent countless hours on porting the old 292 heads,welding and porting on the prostock versions and he only managed 500 to 550 in cup trim.I wish it was that easy for example I have a 355 with 11.5 to1 comp solid roller cam and a set of reed ported 292"s and according to my calcs based on et and mph shes only putting out about 450.The heads were state of the art in the early80's cost the original owner about 3000 in early 80's bucks.levisnteeshirt wrote: ↑Wed Aug 14, 2019 11:44 pm Grumpys and Smokeys books talk about 600hp level 350s ,, late 70s stuff ,, doesn't look difficult ,, Smokeys stock block Indy motor was 675 with a roller cam and mechanical FI , 355 ,, nothing really out there
Re: 600 HP 350 SBC?
Yeah, the solder trick sounds like it'll work. Find the length and enter it here https://www.omnicalculator.com/math/circumference
Re: 600 HP 350 SBC?
You need around 2.2^" mcsa & 265-275cfm at max valve lift through intake & head to make 600hp - if the port if efficient.
Re: 600 HP 350 SBC?
I haven't started on the intake yet but thats about where I expected I would end up.KnightEngines wrote: ↑Thu Aug 15, 2019 9:50 am You need around 2.2^" mcsa & 265-275cfm at max valve lift through intake & head to make 600hp - if the port if efficient.
Re: 600 HP 350 SBC?
If that’s a 1205 gasket on the heads...... then yeh, they’re def not as big as they “look” in that first pic.
As to the original question......
600hp from a 350...... with no rules to go by, I’d just take the path of least resistance.
12-13:1, something like AFR heads, good intake with a little work on it, roller cam, good pan....... shouldn’t be too hard.
- Stan Weiss
Re: 600 HP 350 SBC?
Shawn,RevTheory wrote: ↑Thu Aug 15, 2019 8:30 amYeah, the solder trick sounds like it'll work. Find the length and enter it here https://www.omnicalculator.com/math/circumference
That calculator only works for a circle. The following from Gary's heads
► 1.85 * 1.194 = 2.2089 sq inches area
► (1.85 * 2) + (1.194 * 2) = 6.088 length
The 2.2089 sq in area produces a circumference of 5.26857
