ClassAct wrote: ↑Mon Aug 12, 2019 5:28 pm
GARY C wrote: ↑Mon Aug 12, 2019 4:37 pm
CamKing wrote: ↑Mon Aug 12, 2019 4:28 pm
Yep, if you're geared to turn 4,000rpm, and I'm geared to turn 8,000rpm, I only have to make over half as much torque as you, to beat you.
That's why we calculate torque at a given RPM.
Tell that to the guys in Daytona Prototype that couldn't catch the turbo diesel that were running very low rpm or the drag racers that get out et'ed and mph by the higher tq cars running 3.40 gears... the combination plays a big part into what works.
Higher tq will pull a taller gear and make more wheel speed.
Go tell that to the Pro Stock and Comp Elimininator guys. Diesel is another deal. I don't care about what a diesel does. Hey are dirty, nasty pigs. They are for hauling 80k pounds of junk around. They ain't racing engines.
As to your drag reference, the gear you can pull is related to RPM and HP. Not torque. If you make enough HP to pull a 3.40 gear, that's all you need. Torque didn't matter.
Take two engines. One with 425-430 HP and let's say...800 FT pounds of torque and the other with say 800 HP and 550ish TQ and tell me which one will be quicker. Every single time, the HP will out run the TQ. Every time. All the time. All day long.
A real world example I know of, 2 equally prepared 23 degree headed 421 Nova's, both dynoed within 25 hp and tq of each other, both were the same weight, converter, shocks, springs, one had had a 1.69 glide and a 4.30 gear, the other had a 1.76 glide and a 4.88 gear both were very close NA but the car with less gear was quicker and faster by about a tenth or 2 at a lower rpm, both on a 175 shot it was 3 to 4 tenths quicker, on a 225 shot it was 5 to 6 tenths quicker and always out mph the other car.
Before Roy took gear out of his car it ran the slower times of Scott's car... I don't think it's one or the other, I think it's about power management if your going to get a 3100 lb leaf-spring car to run near 5.00's it takes a complete package, upward motion at the starting line is wasted forward motion.
I could give at least 5 other real world examples of high tq cars going faster by reducing gear and increasing wheel speed but you have to have the tq to make it work.
