How far can I go with the thermactor hump (porting)
mag2555
Re: How far can I go with the thermactor hump (porting)
Post by mag2555 »
You in no means need to grind that out all the way as having that sitting right after the valve guide effects the flow only to the tune of 3 to 4 cfm at most if you Boat tail it on its nose and then trim the rest down into a triangle , in fact you do not even need to lower its height when forming it into a triangle.
Just make up for the guide and that lump being there by widening out the cylinder wall side of the roof some and deepening it .040" starting at the mid lenght of the guide since that's by far the most active side of the roof due to the way flow actually enters the port from Around the valve.
Short lenght Exh ports like that are highly effected by letting the flow go the way it wants to and not kick it around from side to side on the roof.
PRH
Post by PRH »
What kind of power level are we looking for out of this build?
350hp?
Are these 351 heads with 1.78/1.45 valves?
Are you keeping that valve size?
If you had the luxury of a flow bench handy, what kind of ex flow would you be shooting for??
travis
Post by travis »
PRH wrote: Sun Aug 18, 2019 11:25 am What kind of power level are we looking for out of this build?
350hp?
These are 351w heads with 1.78/1.45 valves, although this vintage 351w used 302 heads...the only difference literally being the head bolt holes are slightly bigger.
350hp would be a pipe dream with these things. At this point I don’t think these are worth spending the money or effort to take them any further.
travis
Post by travis »
E5AE-CA heads...pic 1 vs pic 2
.050...20...21
.100...39...40
.200...77...77
.300...105...109
.400...111...121
.500...115...126
.600...116...126
WFO...116...126
Bloody pathetic :lol:
travis
Post by travis »
E5AE intake port, light bowl blend, streamlined the guides a bit, blended the short turn and removed the sharp lip off the bottom of the short turn
.050...32
.100...65
.200...116
.300...148
.400...160
.500...167
.600...167
WFO...167
travis
Post by travis »
Compared to data I have for stock E7TE’s (since I we didn’t baseline the bone stock E5AE ports), a mild bowl blend on these is worth 0-12cfm at any lift point. This was about 2 hours worth of work total for both heads, and still with the stock single 45 seat. Throwing in another hours or so for 1 exhaust port, was worth another 4-10 cfm above.300” lift.
So...basically a complete waste of time, but it was educational. The education being that iron sucks, and ford smogger heads REALLY suck unless you want to spend a very significant amount of time and effort developing them.
Carnut1
Post by Carnut1 »
You make it sound like the infinite grinding isn't worth it!
631-816-4911
9:00am - 9:00pm EST
PRH
Post by PRH »
I wonder how much of that 10cfm on the ex you could get in 5mins?
Whatever it is...... that’s what they’d get!!
Okay, maybe 10mins.
That’s the kind of thing that’s a 3hr job for me....... for the pair.
180mins, 16 ports...... 11.25mins per hole.
Then iiwii.
Gonna need to step up with the cam to get it to 350hp. 8)
travis
Post by travis »
Carnut1 wrote: Sun Aug 18, 2019 3:46 pm You make it sound like the infinite grinding isn't worth it!
It’s only worth it if you’re a bit of a sadist :wink: :lol:
Although now I’m sitting here thinking “what if I took some more off around the guides and laid the short turn back some?”.
Sometimes ignorance is bliss lol
travis
Post by travis »
PRH wrote: Sun Aug 18, 2019 4:05 pm I wonder how much of that 10cfm on the ex you could get in 5mins?
Probably all of it, if you know what your doing lol
travis
Post by travis »
Joe-71 wrote: Sat Aug 17, 2019 10:36 pm It would be much easier with round stones and a high speed grinder such as a Dewalt. Gives a much nicer radius, better control of material removed. The E-7 style EGR hump can be nearly made flat with the roof if done properly in the bowl. Those ports can be brought up to 180 cfm without a pipe. Joe-JDC
The problem is...the damn port is so small that a round stone won’t even fit in there, until after you whittle out a bunch of iron with a burr.
180 cfm?? I am a LONG way from there. I’m assuming that is with a 1.60” valve?
Would there be any benefit to lowering the floor any? Or does the majority of the work need to be roof and cylinder side wall?
What flange dimensions do you end up with? This will have 1.5” headers...I need to get the gaskets ordered so I can see where I’m at
Carnut1
Post by Carnut1 »
travis wrote: Sat Aug 24, 2019 7:41 am
I will see if I can help. That would be 1.6" valve with a good valve job and very good porting job. Do not make the flange dimensions larger than stock! The flange is not the restriction. The floor, just clean up issues. Do not hog out bowl, expand the bowl in areas the air needs to expand to get around obstructions. I start with guides and a valve job first.
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket »
Any pics on this mystery?
Carnut1
Post by Carnut1 »
gmrocket wrote: Sat Aug 24, 2019 10:32 am Any pics on this mystery?
Not for this exact exhaust port. Last set I did like this was low performance, more of a cleanup which did net decent improvement in flow.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
This is a 289 casting exhaust port with some work. Notice how the bowl enlarges a bit for the flow to go around the valve stem. This pic is off my Ported 289 thread. These heads did not have the large boss in the port.
631-816-4911
9:00am - 9:00pm EST
