Crank failure
Re: Crank failure
Rick! wrote: Mon Aug 19, 2019 6:00 pm
PackardV8 wrote: Mon Aug 19, 2019 12:26 pm
Steve.k wrote: Mon Aug 19, 2019 11:55 am Any specific reason why crank would break in front of front main? 700hp na? Forged Steel.? 438 inch sbf.
Maybe, it's just exceeding the limits of the SBF crank snout and damper architecture, designed for sub-300", sub-300hp. For comparison of what engineers provide when they know that area will be heavily loaded for long duration, look at the crank snout on an FT 361"-391" truck engines. It's 1.75" diameter, vs 1.375" on a stock SBF, a 28% greater area cross-section and diameter.
1.75²/1.375² DNE 28%. Straight up diameter to diameter, yes, but area is a different calc.
For true; don't trust math by someone who went to high school more than seventy years ago, but your diameter squared formula won't get us there either.
The formula for area of a circle is A=πr2:
.875 x .875 x 3.14 = 2.4
.6875 x .6875 x 3.14 = 1.48
2.4 - 1.48 = 1.2
1.2 / 1.48 = 62% greater area
jake197000
Re: Crank failure
Post by jake197000 »
maybe it was just a faulty crank.it happens.
superpursuit
Re: Crank failure
Post by superpursuit »
I assume that you were NOT running it externally balanced at that power level?? No crank likes that.
You mentioned that it is an offshore crank that you won't say any names.
If it starts with pro then this is normal from what I've seen.
ssmmith
Re: Crank failure
Post by ssmmith »
As has been mentioned, make sure the bottom gear radius matches or exceeds the radius on the nose of the crank. some crank companies are running an extremely long harmonic balancer bolt that actually goes into the front main of the crankshaft and sometimes into the front counterweight, at first I thought it was overkill, but it pulls the nose towards the crank making a stronger method of attachment. Also if externally balanced will make a difference. Good luck and I hope you didn"t kill too many other parts. Steve
BillK
Re: Crank failure
Post by BillK »
Steve,
I have seen one before that a customer brought in. He had used a 9 keyway crank sprocket and you could see the indentation of all of the cutouts all the way around the crank and that was exactly where it broke. Same deal as someone else mentioned, not enough chamfer on the sprocket to allow it to sit flat.
leahymtsps
Re: Crank failure
Post by leahymtsps »
BillK wrote: Tue Aug 20, 2019 12:42 pm Steve,
X2 I've seen the same with a 9 tooth gear with the same results
Tom
Steve.k
Re: Crank failure
Post by Steve.k »
wasn't what i thought guys. It was a rpm crank maybe found limits?
Steve.k
Re: Crank failure
Post by Steve.k »
. I should have known something up. It slowed a bit but couldn't figure why. Must've cracked putting pressure on front main. Then once main spun and started moving she let go more. Timing chain let go and that was that.
Steve.k
Re: Crank failure
Post by Steve.k »
each bank not sure if it cleaned soot off before or after chain let loose. Other than rich she was tight.
1972ho
Re: Crank failure
Post by 1972ho »
That’s about where my V-6 even fire crank broke was this a standard cleveland journal size or smaller mine was a 2.100 journal that was .905 wide.
ProPower engines
Re: Crank failure
Post by ProPower engines »
Same thing I have seen as well. But also fluid dampers will snap the nd of a crank like that on decel as well.
Too much weight on the end works against the crank when it tries to unwind...............snap-0
Steve.k
Re: Crank failure
Post by Steve.k »
Was a good name cleveland balancer and everything neutral balance so who knows. It made 703 at sea level but was way below that at this altitude.
ssmmith
Re: Crank failure
Post by ssmmith »
Steve, I have been around crankshafts for a little while. The one that I broke like that I Know for a fact that it was balancer related. It broke right in the same place as that one. This was one that I made from a raw forging. It was a lot thicker on the front rod cheek than that one. the outer ring of my balancer came off and I ran it anyway. I was young and thought it wouldn't hurt for a week or two. Since that I have only ran ATI balancers and haven't broke one since in that place. I did break a stock cast 454, but it was making a little more power than a cast crank could hold for about 3 or 4 years. It broke at the rear rod. I know ATI is an expensive piece but worth it.
Good luck, Steve
Steve.k
Re: Crank failure
Post by Steve.k »
Thanks ssmmith it could be. I had a different balancer on this motor that spun. Maybe it started the problem?Hopefully i can fix block. Took a little material out of block main saddle on chain side.
Kevin Johnson
Re: Crank failure
Post by Kevin Johnson »
IF the break is aligned with the terminus of the snout bolt THEN the stress raiser caused by the deformation of the initial fastener threads could finally have done it. Hypothesis.
