blown olds
rocketracer380
blown olds
Post by rocketracer380 » Fri Aug 30, 2019 1:06 am
olds 350 with 144 blower
travis
Re: blown olds
Post by travis » Fri Aug 30, 2019 2:31 am
Is that a question, or a statement? :?
mag2555
Re: blown olds
Post by mag2555 » Fri Aug 30, 2019 6:11 am
Might this be the answer to your bazaar criptic post ,You'll not get more then about a extra 125 hp ( some 5 to 6 psi of boost) out of that blower if that covers your needs?
gmrocket
Re: blown olds
Post by gmrocket » Fri Aug 30, 2019 6:37 am
Here I'll finish it for you,,,KABOOM!
dfarr67
Re: blown olds
Post by dfarr67 » Fri Aug 30, 2019 11:20 am
Thanks, I needed that this morning ;)
Re: blown olds
Post by F-BIRD'88 » Fri Aug 30, 2019 11:59 am
Are you interested in doing that? .....or?
mag2555
Re: blown olds
Post by mag2555 » Fri Aug 30, 2019 12:15 pm
Can someone loan me a Rosetta Stone for this string of post please or am I missing the fact that the motor has met its demise?
rocketracer380
Re: blown olds
Post by rocketracer380 » Sat Aug 31, 2019 2:38 pm
has anybody done it i have an offehauser dual quad intake i can modify
Dave Koehler
Re: blown olds
Post by Dave Koehler » Sun Sep 01, 2019 7:16 am
I so want to say...get a real blower. Ok. I did it. I feel cleansed now.
It has been done and I suspect Dyer Blowers has the answer.
PS, there are punctuation and upper case keys on your phone.
Re: blown olds
Post by F-BIRD'88 » Sun Sep 01, 2019 9:34 am
If you do not already own the 144 blower start with a bigger better blower. X2 if you want more than 450 HP.
Re: blown olds
Post by F-BIRD'88 » Mon Sep 02, 2019 11:37 am
If I had a Olds 350 sb and the Offy dual quad manifold for that and wanted to supercharge it I'd use a TorqStorm blower and use 2 edelbrock 750 cfm carbs .
Carbs can be in a carb box.
Best street strip results if the engine has a low compression ratio.
rocketracer380
Re: blown olds
Post by rocketracer380 » Sun Sep 08, 2019 8:48 am
Is 550hp attainable with the Weiand 142 on a 358 with heads and blower cam
Re: blown olds
Post by F-BIRD'88 » Sun Sep 08, 2019 10:42 am
Yup bolt the blower onto a 560 HP 358.
You'll get 550 HP.
Seriously a 177 Weiand or the 192 billet TBS blower both
Achieve that power level and more on a 358 very nicely.
The 142-144 blower is going to peak out about 480 HP on a high cr high blower drive ratio, maxed out 358.
Methanol or water injection.
It is very good in the 450-460 HP range.
Dave Koehler
Re: blown olds
Post by Dave Koehler » Sun Sep 08, 2019 11:47 am
Ok, this has to be a street machine.
Consider this..a boosted engine that makes 400 HP on the street can kill you.
How much over that is really useful in a traction limited application?
Any supercharged engine is a blast.
My point is do what you want regardless of what HP it may or may not make here on the internet.
If there is no dyno in your town it can be rated at whatever HP you choose. :wink:
