Bench Data
Carnut1
Re: Bench Data
Post by Carnut1 » Sun Sep 01, 2019 7:24 pm
SpeierRacingHeads wrote:
Sun Sep 01, 2019 6:31 pm
Carnut1 wrote:
Sun Sep 01, 2019 1:36 pm
They look great and I expect they will make a serious street sweeper. The fast floor doesn't bother me if it has a low speed gradient across the floor and has a smooth sound at higher depressions. Please share some cfm and shortblock specs. Thanks, Charlie
Port is about 188cc. 2.08 LS valve. Flows 300@.500 and 305@.600, and 308@.700
4.165 x 3.48
Scat 9000 crank and rods
Weisco Pro Tru pistons
TPiS 231/236 roller cam
.580 lift
Morel lifters
NHRA legal stocker pan
That is a fast port. That will work great. Thanks for sharing.
631-816-4911
9:00am - 9:00pm EST
SpeierRacingHeads
Re: Bench Data
Post by SpeierRacingHeads » Sun Sep 01, 2019 9:21 pm
4.165 x 3.48
.580 lift
Morel lifters
I'm going to dyno it. Just will need to be with a manifold and carb. My dyno I use doesn't have the injector setup. And that would be a PIA.
Speier Racing Heads
Chad Speier
785-623-0963
GARY C
Re: Bench Data
Post by GARY C » Sun Sep 01, 2019 10:11 pm
ClassAct wrote:
Sat Aug 31, 2019 6:34 pm
Chad, have you ever done any port development with the opposite shape?? As in, have you ever raised and made the roof of the port square, while leaving the floor round? Just curious as to what you think.
You mean a "Rectoval?"
Mikej26
Re: Bench Data
Post by Mikej26 » Mon Sep 02, 2019 3:36 am
4.165 x 3.48
.580 lift
Morel lifters
I think it’s going to be surprisingly good. Looking forward to seeing the dyno results
econo racer
Re: Bench Data
Post by econo racer » Mon Sep 02, 2019 5:43 am
Chad have you made a pass at the drag strip yet? Something to get a baseline from?
Carnut1
Re: Bench Data
Post by Carnut1 » Mon Sep 02, 2019 7:28 am
4.165 x 3.48
.580 lift
Morel lifters
It may be helpful it you flow it all together with cylinder head, carb and intake vs. Injection and throttle body before you dyno. If the airflow is close you will get a fair idea how the other will be.
631-816-4911
9:00am - 9:00pm EST
Elroy
Re: Bench Data
Post by Elroy » Mon Sep 02, 2019 1:08 pm
What is the power and torque goals? Solid roller?
SpeierRacingHeads
Re: Bench Data
Post by SpeierRacingHeads » Mon Sep 02, 2019 1:11 pm
It's a street car, I would never race it.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Re: Bench Data
Post by SpeierRacingHeads » Mon Sep 02, 2019 1:12 pm
String of 500hp and string of 500 torque, peaking at 6200ish
Yes, small solid roller
Speier Racing Heads
Chad Speier
785-623-0963
3V Performance
Re: Bench Data
Post by 3V Performance » Mon Sep 02, 2019 2:41 pm
Peak of 6200 cfm demand is about 290ish. 379ci
Better line of sight the speeds over the short side can be higher is what I found. I bet its pretty dam good. :wink: fast.
3V Performance
" ENGINES WITH AN ATTITUDE "
980-222-7230
RevTheory
Re: Bench Data
Post by RevTheory » Mon Sep 02, 2019 4:02 pm
Chad, with your super-stock heads in mind, what's your velocity "uncle point" over the turn when you're not bound by rules? If it's pushing 420 fps but not separating on the bench up to .800 lift, is that a bad thing in this particular application?
It's not like a circle track deal where you're afraid it's going to trip over it's tongue on the back stretch.
SchmidtMotorWorks
Re: Bench Data
Post by SchmidtMotorWorks » Mon Sep 02, 2019 4:10 pm
This is a velocity chart with the different velocities shown in stepped bands of colors.
It illustrates what is going on when you raise the top of a port.
Steve Haaf
Re: Bench Data
Post by Steve Haaf » Mon Sep 02, 2019 7:08 pm
Chad, I`m thinking leave as is, put your whole induction system together and flow it. That should slow things down. That CFM and velocity would really help part throttle response.
GARY C
Re: Bench Data
Post by GARY C » Tue Sep 03, 2019 12:19 am
Doesn't change as much as one would think.
Elroy
Re: Bench Data
Post by Elroy » Wed Sep 04, 2019 2:28 pm
Walk in the park. 500 tq is more of a challenge than the 500 horsies but neither should be much trouble at all for something with some effort thrown at it. There are out of the box heads that could get that done. I have a suspicion you are intentionally understating your goals because of the TPI///understandable but dynoed with single 4.//solid roller 379 with ported heads and manifold////570 plus or its broken.
