Page 4 of 10
Re: Bench Data
Posted: Mon Sep 16, 2019 9:39 pm
by MadBill
Be interesting to test-glue in a turning vane down the centerline. In the stock elbows of a 1988 Firebird system I tested, they added ~ 4% each.
Re: Bench Data
Posted: Mon Sep 16, 2019 10:32 pm
by Outlaw383
Chad you stated those were too fast, what fps would you prefer to see in that area of the floor on a head that size ?
Re: Bench Data
Posted: Tue Sep 17, 2019 11:37 am
by SpeierRacingHeads
Outlaw383 wrote: ↑Mon Sep 16, 2019 10:32 pm
Not sure I care as long as it's the same across and the SSR can handle it with shape or volume.
Re: Bench Data
Posted: Thu Oct 03, 2019 12:08 pm
Started bench work. Baseline.
Flow test with just head
Middle with elbow/TB
Bottom with Carb
Re: Bench Data
Posted: Thu Oct 03, 2019 4:56 pm
by Carnut1
If anyone can get that air to bend around it would be Chad. I like the plenum mods.
Re: Bench Data
Posted: Thu Oct 03, 2019 5:16 pm
by MadBill
OK, I spent way too much time trying to figure out in the last pic how what looked like chunks of foam rubber stuffed in the runners was really some sophisticated epoxy fill job. It finally clicked that it
was foam, plugging the runners that were not being flowed.
Re: Bench Data
Posted: Thu Oct 03, 2019 5:32 pm
by FC-Pilot
MadBill wrote: ↑Thu Oct 03, 2019 5:16 pm
On my Ipad I thought he filled the floor of all but one runner. It was a good thing I did not mention anything until I saw it on a full size computer screen. Yep, just foam. LOL
Re: Bench Data
Posted: Thu Oct 03, 2019 6:23 pm
by GARY C
FC-Pilot wrote: ↑Thu Oct 03, 2019 5:32 pm
I am not going to admit I thought the epoxy thing also.
Re: Bench Data
Posted: Thu Oct 03, 2019 9:09 pm
Foam out of Ferrea boxes!
Simple and easy.
Re: Bench Data
Posted: Fri Oct 04, 2019 12:37 pm
I think it's golden. 6% loss to the front runner through the elbow/TB.
Re: Bench Data
Posted: Fri Oct 04, 2019 2:22 pm
by Carnut1
I think that is excellent that you only lost 6% on the front. I am interested in the difference flow wise from front to back on the manifold. Thanks, Charlie
Re: Bench Data
Posted: Fri Oct 04, 2019 2:49 pm
by Elroy
Good flow// Excuse me if this has already been said////what made you decide to change to a different head casting?////Was the first set coming up short of flow goals?
Re: Bench Data
Posted: Fri Oct 04, 2019 3:00 pm
Elroy wrote: ↑Fri Oct 04, 2019 2:49 pm
No, I just wanted to use my CNC 205cc head.
Basically I built a 13-1 (4.165x3.48) drag engine (VP113) with the same heads and a 260/268 w/.680 lift and I want to see what this does (same bore/stroke) on the same dyno with 11-1 (91 octane) and a 231/236 w/.580 lift.
Just trying to learn something!
Re: Bench Data
Posted: Fri Oct 04, 2019 3:13 pm
by Elroy
OK good go then.////////should have more than enough flow for the goal//should be easy to get there.
Re: Bench Data
Posted: Fri Oct 04, 2019 3:20 pm
Elroy wrote: ↑Fri Oct 04, 2019 3:13 pm
I agree. I put LS 8mm valves in these heads and using a small dual roller spring.
I will need to dyno with a carb, which just saves the injector harness grief.
I will chassis dyno it, so I will have all the data I need.. I hope.
