This is a less common version of the Air Gap, shortly produced by Dart.
Looking for tips and opinions how to improve flow.
Any input appreciate, thank you.
Porting a Dart Kool Can intake
- New Member
Re: Porting a Dart Kool Can intake
They still make it, just call it the SHP now
Sell it and buy an eddy rpm air gap think the plemum is larger and I deff rem the runners(not ports/flange openings) are a bit larger. Dart 6000rpm, Eddy 6500rpm
Just check the intake bolt holes on the eddy so they don't bind and distort the flange I have fixed 3 but supposedly eddy improved their intake quality on some not too long ago.
Otherwise just a basic clean up
If you want a larger plenum the Weiand Air strike has a much larger plenum. Fyi, Why sell it? It probably flows nearly the same as the eddie, was probably cast by them too. If you don't need more than about 230 cfm (a guess) it will work. A basic cleanup may add a few cfm. It looks like a solid design to me.BOOT wrote: ↑Sun Sep 01, 2019 5:22 pm They still make it, just call it the SHP now
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Nothing wrong with the SHP, I just figured if he wants to port a dual plane, then why not start with one larger already since porting a dual plane is not ideal for most. My opinion is the weiand has a larger plenum to compensate for not having the divider cut out and also is a good intake.
Dart claims eddy copied their design so I don't think that would be the case. Still side by side the runner paths are a bit diff, not a lot but it made a diff on my dist vac can getting in the way.
I based my response on his desire to port the intake and nothing else provided, no clue what he has or what intake would work best for him.
- New Member
Will try what I've got first. Must say that the Stealth also looks promising. Or maybe a Holley 300-36 whatever I can get my hands on first.
