Dart 180 cc alloy head as cast
Re: Dart 180 cc alloy head as cast
The AR among us might feel differently, but since the mandrell is symmetrically shaped, small in diameter and has a very low moment of inertia: No need.
Bill,
thanks for the reply
much appreciated
much appreciated
How many CFM do you need to make 550 HP on a 10.5-1 comp 383 cube engine with a 230s duration cam ?
Randy
Randy
270 cfm through induction, 290 cfm on bench at your lift of cam, on an honest dyno w/91 octane
Steve, as an example where I dyno..
383 w/as-cast 180 heads, 14-1, 244/244 w/350 2 barrel makes 370hp
383 w/Vortec, 11-1, 228/232 w/750 makes 480hp on alcohol (derby engine)
All dyno and flowbench read low ////age old argument///how often do you hear the opposite?//dyno differences led to dyno competitions years ago///all engines same dyno no argument//most people no little about dynamometers and their operation
LOL Exactly !!
That's what's cool about the EMC, all engines on the same dyno, high, low, or spot on it's the same for all.
Randy
Guess you guys have never seen a recent new DTS/Superflow sheet!
Not all dynos are the same, debate it all you want.
I don't believe anyone is debating that//only that engine constest are done on same dyno to eliminate that variables and nobody advertises or says theyre dyno reads high/I have used most all major dynos. They can all be high or low//not wanting to derail cowan thread any further maybe I will start a new post and we can discuss your low reading dyno and the causes you trace that to? maybe in a different section//all dynos have possibility for high or low error. Repeatability is key along with an understanding of the equipment at hand//surprising how many people don't understand the machine they are using or own.SpeierRacingHeads wrote: ↑Mon Nov 18, 2019 12:59 pm Not all dynos are the same, debate it all you want.
Not sure why the engine contest is being mentioned? Is that to validate the other dyno?Elroy wrote: ↑Mon Nov 18, 2019 2:06 pmI don't believe anyone is debating that//only that engine constest are done on same dyno to eliminate that variables and nobody advertises or says theyre dyno reads high/I have used most all major dynos. They can all be high or low//not wanting to derail cowan thread any further maybe I will start a new post and we can discuss your low reading dyno and the causes you trace that to? maybe in a different section//all dynos have possibility for high or low error. Repeatability is key along with an understanding of the equipment at hand//surprising how many people don't understand the machine they are using or own.SpeierRacingHeads wrote: ↑Mon Nov 18, 2019 12:59 pm Not all dynos are the same, debate it all you want.
Everything goes back to EMC. BIG World out there.
I'm not understanding?
But yea, Steve will be OK..
The underlying premise of outing other's "happy Dynos" appears to be a form of virtue signalling via "Lower = honester."Elroy wrote: ↑Mon Nov 18, 2019 2:06 pmI don't believe anyone is debating that//only that engine constest are done on same dyno to eliminate that variables and nobody advertises or says theyre dyno reads high/I have used most all major dynos. They can all be high or low//not wanting to derail cowan thread any further maybe I will start a new post and we can discuss your low reading dyno and the causes you trace that to? maybe in a different section//all dynos have possibility for high or low error. Repeatability is key along with an understanding of the equipment at hand//surprising how many people don't understand the machine they are using or own.SpeierRacingHeads wrote: ↑Mon Nov 18, 2019 12:59 pm Not all dynos are the same, debate it all you want.
i think the dyno conversation would be great
i have never been on a dyno so any information would be appreciated
as far as EMC- pretty good platform to make power in certain rpm parameters
debate all you guys want,i am happy for the discussion
When I say "happy dyno" I'm talking about the conversion used back to corrected power. There is like 4 or so being used, currently.MadBill wrote: ↑Mon Nov 18, 2019 2:47 pmThe underlying premise of outing other's "happy Dynos" appears to be a form of virtue signalling via "Lower = honester."Elroy wrote: ↑Mon Nov 18, 2019 2:06 pmI don't believe anyone is debating that//only that engine constest are done on same dyno to eliminate that variables and nobody advertises or says theyre dyno reads high/I have used most all major dynos. They can all be high or low//not wanting to derail cowan thread any further maybe I will start a new post and we can discuss your low reading dyno and the causes you trace that to? maybe in a different section//all dynos have possibility for high or low error. Repeatability is key along with an understanding of the equipment at hand//surprising how many people don't understand the machine they are using or own.SpeierRacingHeads wrote: ↑Mon Nov 18, 2019 12:59 pm Not all dynos are the same, debate it all you want.
Selling engines = highest
Dynoing competition = lowest
25 years worth of data is also another conversation. LOTS of older shops with tones of data. They still compare. They still use it. They might be a little more on the "tight" side. MY OPINION because I've seen it over and over.
THE BEST way to know where you stand is ask the operator, what conversion? And what would be killer on your dyno for power.
A few years back, a friend of mine bought a 358" SBC with a dyno sheet showing just over 600 HP. It had some decent parts in it, but nothing that could get it close to that number. I pointed out that the sheet was dated in late winter, so the 14% CF shown could only have have come from a dyno at the top of Pike's Peak...SpeierRacingHeads wrote: ↑Mon Nov 18, 2019 2:59 pm...THE BEST way to know where you stand is ask the operator, what conversion? And what would be killer on your dyno for power.
