Dart 180 cc alloy head as cast
Locked
steve cowan
Re: Dart 180 cc alloy head as cast
Post by steve cowan »
Elroy wrote: Mon Nov 18, 2019 7:43 pm
MadBill wrote: Mon Nov 18, 2019 2:47 pm surprising how many people don't understand the machine they are using or own.
SpeierRacingHeads wrote: Mon Nov 18, 2019 5:11 pm Stuska doesn't have a interia factor as a entered number.
Ok. dont take this as anything but constructive it just proves my point and shows there are many in the dark.///A stuska has to have an inertia factor entered or else its been hybridized, converted, has different acquisition...///or its no longer a stuska dyno////this is not to say that continually changing it for different platforms is required or necessary for development.///repeatability=internal development///
Its entirely possible the dyno owner has never touched its initial setting or knows of it////not uncommon//the problem comes from the this dyno reads low crowd///and like I say they all do read low just ask the owner of one :D If everyone was on top of the workings of their dyno/regional comparisons can become much more meaningful//I have witnessed very good consistency from one dyno to the next myself///but it takes knowing and staying on top of things along with having a dyno owner that doesn't have too much ego to admit he don't know why some things are the way they are///bottom line..a stuska dyno is extemely intertia factor dependent.
SpeierRacingHeads wrote: Mon Nov 18, 2019 5:11 pm The dynos at EMC did however, which were DTS.
Last i looked dts was using a bit of inertia factor input into their correction math////very small component compared to stuska///small enough that at a dyno contest like enc i foresee there would be more inaccuracy and conflict amongst competitiors by changing it than if left alone///back to the point of a engine dyno contest////everyone dynos on the same dyno///everyone knows the rules going in///build an engine friendly to that small amount of inertia factor input..its very small///i would bet the teams that do well at those events know some things about how a dyno works////watch and listen to some videos on engines making pulls on dts, superflow, stuska///you can generally hear why a stuska needs inertia applied//almost my bedtime and i missed wheel of fortune #-o
Elroy,
thanks for the contribution
i think everyone can learn something from that post :D
zums
Post by zums »
I would spend some time on the vic jr on the bench with a probe, no sense sinking tons of time in the heads without sorting the vic, get your csas in shape, i dont see why 245-255 through the induction wont get you where you want to be
Tom
SpeierRacingHeads
Post by SpeierRacingHeads »
Can anyone post a link to any major engine builder doing a 383/550hp crate engine?
Speier Racing Heads
Chad Speier
785-623-0963
PRH
Post by PRH »
SpeierRacingHeads wrote: Tue Nov 19, 2019 6:47 pm Can anyone post a link to any major engine builder doing a 383/550hp crate engine?
Seems like the cubes sell....... and since a 427 isn’t really anymore expensive to build from all new parts than a 383........ it doesn’t seem like many people are building higher effort 383 crate motors.
402”, 10:1, hyd roller, unported heads, RPM intake:
https://www.shafiroff.com/chevy-pump-ga ... street.php
SpeierRacingHeads
PRH wrote: Tue Nov 19, 2019 7:09 pm
Not sure some think it's a "higher effort" build??
I get the impression the as-cast 180 should make that.
Speier Racing Heads
Chad Speier
785-623-0963
PRH
Post by PRH »
Here’s one...... 383, 537hp...... uses AFR 195’s:
https://westcoastengines.com/383-stroker/525-hp/
Here’s another one...... uses AFR 210’s:
http://www.whiteperformance.com/engine_ ... 562hp.html
My point was, it’s not hard to find pretty mild street 383’s....... like a GM ZZ build or equivalent.
The 550hp pump gas builds just seem to usually end up being built from more cubes.
SpeierRacingHeads
PRH wrote: Tue Nov 19, 2019 7:17 pm Here’s one...... 383, 537hp...... uses AFR 195’s:
All much larger than 180cc and both far from as-cast.
That was my point. It's going to take some cylinder head to make 550hp from a 383 SBC.
Speier Racing Heads
Chad Speier
785-623-0963
PRH
Post by PRH »
I agree.
I’d think something flowing a solid 275-ish in the 200cc range would get it done.
SpeierRacingHeads
PRH wrote: Tue Nov 19, 2019 7:37 pm I agree.
Yes, I agree..
We did one that made 550 on pump gas, but needed a solid roller to get it done.
Vacuum pump would have helped. 10-1 compression
Import head that flowed 270 through manifold/carb.
Speier Racing Heads
Chad Speier
785-623-0963
PRH
Post by PRH »
“Needed a solid roller cam”??
As in...... you started out with something different, and couldn’t reach your goals with it, and then swapped to a solid roller??
Or..... you just started out with the solid roller in the first place??
SpeierRacingHeads
PRH wrote: Tue Nov 19, 2019 7:57 pm “Needed a solid roller cam”??
Started out with a roller, just like I did but mine was much smaller.
IMO, HYD rollers suck.
Speier Racing Heads
Chad Speier
785-623-0963
steve cowan
zums wrote: Tue Nov 19, 2019 6:08 pm I would spend some time on the vic jr on the bench with a probe, no sense sinking tons of time in the heads without sorting the vic, get your csas in shape, i dont see why 245-255 through the induction wont get you where you want to be
Tom
Hi Tom,
Good to hear from you
I have a new Holley strip dominator intake as well I want to look at, seems like a better fitting intake compared to the victor. I had a dream of testing 2 different intakes at the dyno but I doubt it would happen lol
steve cowan
So the discussion has been great, thank you to all involved.
Want to be clear -
There are a few guys on the forum that can make great power with as cast heads, I am NOT one of them :D
Back to tech
This is my plan so far
11.5 :1 comp
MS 109 or sunoco 260 at the track
Pump 98 on the street
Low tension oil ring and vac pump
5.7"rod
Cylinder head
2.3" at the pinch ( already done)
2.02"valve @ 89% 2.52"CSA
2.4" average CSA
Once it is all said and done the head will be 200-205 cc
If I can get close to the cfm/ sq inch at the throat, pinch, valve etc
I would think the result would be approx 290-295 cfm
As far as cam goes
Intake around 240degrees at 0.050"
With a closing point of 45degrees
Exhaust I would think more duration and an exhaust opening of approx 55-60 degrees at 0.050"
This makes the Howard's roller a bit small on the exhaust side and I think 0.600" plus lift would make alot more sense.
I have another Howard's roller
257-263 @ 0.050"
680" lift with 1.6 rocker
106LSA 4 degrees advance ground
4/7 swap
But I think this cam might be to big on intake duration.
CGT
Post by CGT »
steve cowan wrote: Wed Nov 20, 2019 2:37 amMS 109
Neat fuel, but expensive.
steve cowan wrote: Wed Nov 20, 2019 2:37 am Low tension oil ring and vac pump
I would suggest making some pulls each way. There is usually always something to learn for future builds by doing so.
steve cowan wrote: Wed Nov 20, 2019 2:37 am With a closing point of 45degrees
IVC of 45° is pretty close for a 6500rpm 383 in my opinion, give or take depending on some things.
steve cowan wrote: Wed Nov 20, 2019 2:37 am Exhaust I would think more duration and an exhaust opening of approx 55-60 degrees at 0.050"
I agree on the more duration. I think a 60° or even earlier EVO would help the top without hurting the bottom...once again depending on some things :D Low 240's intake high 250's exhaust 110 lsa would be about where I'd be on it.
paulzig
Post by paulzig »
CGT wrote: Wed Nov 20, 2019 10:06 am
238IN 254EX on 110 with 4 degrees advance would get you the 45IVC and a 61EVO... Might get some odd looks on the 16 IN/EX split though :) You could do a lovely hydraulic roller with lobes like that...
Locked
