QuickTime Balance Plate RM-531 360 mopar balancing
crazycuda
Post by crazycuda » Wed Sep 04, 2019 3:02 am
Doing a motor swap 273 to 360 and been hunting a good used 130 tooth 10 1/2" external bal flywheel with no real luck in the land of affordability. I stumbled across the QuickTime Balance Plate RM-531. (I have used similar on 400 sbc before with out issue) has anyone else used one on a mopar and not had go re-balance the recip assembly.
A little side note, the larger 143 11" flywheel it is to large (diameter) to fit in stock bell already tried that route. (joys of an early a body)
Sorry if I ask alot of questions, but you never stop learning if you ask questions
n2xlr8n
Re: QuickTime Balance Plate RM-531 360 mopar balancing
Post by n2xlr8n » Wed Sep 04, 2019 5:57 am
I don't know the answer to your question, but Ross @ Quicktime (or whoever owns them nowdays) will help:
(641) 660-2807.
ClassAct
Post by ClassAct » Wed Sep 04, 2019 8:52 pm
I don't know of a bell housing for the small block that took the 143T flywheel ever. You don't need it anyway. A 10 inch clutch is plenty.
crazycuda
Post by crazycuda » Sun Sep 08, 2019 1:00 am
Just a fyi Centerforce 700450, Pioneer Automotive FW-159,Perfection Clutch 50-3413 and Ace Clutch RFW-115 list the 143t flywheel for the small block. My guess is mopar used a bigger bell on trucks or the b-e bodies
Dave Koehler
Post by Dave Koehler » Mon Sep 09, 2019 4:36 pm
I have not purchased or checked the QT chrysler version but the chevies and fords were accurate enough.
I assume you are using an aftermarket convertor with no weight attached to it, correct?
