Air/ fuel ratio data logger
2x4b4fun
Re: Air/ fuel ratio data logger
Post by 2x4b4fun » Wed Sep 11, 2019 4:03 pm
LM-2
henry
donforeman
Post by donforeman » Thu Sep 12, 2019 1:53 pm
Innovate Lm-2 is a good choice. AEM makes both wide band o2 sensor controllers and has data loggers that are not too expensive. They have a very good reputation for accuracy. I have the AEM wideband controller kit that does not have a gauge - 30-0310. It goes direct to the logger of your choice, it does not have to be AEM even. It was a tossup for me between that and the LM-2, advantages and disadvantages to both.
David Redszus
Post by David Redszus » Thu Sep 12, 2019 4:53 pm
We recommend, use, and sell the AEM over the Innovate.
MasterUMC
Post by MasterUMC » Thu Sep 12, 2019 8:02 pm
If you can find an Innovate DL-32 thats what you want. It can take up to four 5 volt sensor device inputs and also has a G force and Vacuum (built in) Best thing about it is it also has a removable SD Card where it auto stores the data.
I picked one up for $125 and use it in my track car.
Also if you need more data inputs you can add an SSI-4 (not the plus) to add 5 more data inputs from any 5 volt sensor.
Mattax
Post by Mattax » Fri Sep 13, 2019 12:44 pm
6 cylinder puller wrote:
Fri Sep 06, 2019 9:51 am
Yes I do understand that, just bouncing questions of of people would are a lot better at this than me. Just trying to find a simpler way to help me start to educate myself in how to tune engines better. 👍
Ah ha! Well, you've already been led toward a false path (and I know, because I went down it).
The AFR logger is not the tuning device you've been led to believe.
There are many reasons why. One is that its not really an AFR logger. Its interpretation of a sensor's response to oxygen.
It is a useful tool in many situations but its not the be all, end all.
Fri Sep 06, 2019 9:15 am
Would reading the plugs be better ?
Reading plugs after a pull is definately a good way to get an idea of what was going on inside the combustion chamber.
Or what would a good desired air/fuel ratio be ?
On a pull? The one that produces the most torque over the rpms you're looking at.
Start here. there is no need to join evil Tapatalk. Just click no thanks and read what's there.
https://www.tapatalk.com/groups/racingf ... html#p3408
if you're making a pull, most chassis dynos have a WBO2 that can be run with it using a tailpipe sniffer.
That will show any major trends (like going richer or leaner) during the pull.
It will be logged simultaneously with the mph and/or rpm, which is really required for a WBO2 AFR to be useful on a wide open throttle pull.
At idle, CO is probably a better way to see AFR, depending on the setup. Once in while you can find a CO meter for sale.
In situations other than idle or WOT, it is very helpful to know the throttle postition and/or manifold vacuum (pressure if you prefer to look at it that way).
donforeman
Post by donforeman » Sat Sep 14, 2019 11:11 am
Yes there are a few things that can throw a wideband o2 off like a lot of overlap at idle and misfires, but seriously with a few exceptions its very good for tuning. Even the five gas can lead you down a rabbit hole if you are not paying attention. Mine would loose calibration once in a while so its gone, it was also a very expensive piece of equipment and not all that portable. Both the Innovate LM-2 and Aem Data loggers have inputs that can track other helpful data like TPS and Pressures and that does help complete the picture so we are not in complete disagreement. I would say that he is very much on the right path, with just a few minor exceptions to keep in mind.
Post by MadBill » Sat Sep 14, 2019 6:04 pm
A common poor boy data logger is a video recorder pointed at the instruments. I believe capturing readable data requires analog gauges.. (or maybe a Super 8 camera)
peejay
Post by peejay » Sat Sep 14, 2019 6:15 pm
I've done this for years.
That's the pisser. Digital video cameras do not work with LED based gauges due to the way LEDs are dimmed.
smeg
Post by smeg » Thu Sep 19, 2019 4:07 am
I have an Innovate ST-12 going cheap.
Mattax
Post by Mattax » Fri Sep 20, 2019 9:11 am
I think we are in agreement. My main point was an AFR log alone is not a simpler path to tuning. Tune for performance and use the WBO2 in combination with rpm (along with MAP or TPS if possible) for tracking the effect of fueling changes. That any article or marketing impliyimg a tuner simply needs to target an AFR number is offering a false path to tuning bliss. The example of a situation where a AFR interpretation can be wrong was just meant to be a lead in example.
David Redszus
Post by David Redszus » Fri Sep 20, 2019 12:33 pm
Just reviewed some Lambda values for a drag racer.
Just off the line the mixture went massively lean and acceleration G forces dropped.
One second later the mixture recovered and held steady slightly rich of stoich at 10,000 rpm.
Near the end of the run, the mixture again went erratically lean.
Was this irregular and inconsistent Lambda reading due to carb behavior or ignition issues?
Or crap fuel?
Tuner
Post by Tuner » Fri Sep 20, 2019 1:24 pm
Or crap fuel?
Without more details about the car and carb, etc, and assuming it actually is lean, not over-rich misfire fooling the O2, it sounds like a Holley carb that needs jet extensions.
Post by F-BIRD'88 » Sat Sep 21, 2019 11:35 am
Do not use the afr reading to set the idle on a carbed engine.
For test and tune to find best wot jetting I use the output of a NB O2 sensor data loged thru my multimeter serial output to my laptop.
It is only intended to show if the tuning progression is resulting in a TOO lean jetting, as a warning device.
Tune for best overall power. The data log and plug appearance help keep you out of trouble.
You don't need to know the exact AFR.
A AFR guage and or a afr data log is at best a usefull You're too lean". -- warning device for when tuning.
It can show some ignition faults too.
