Low speed (1500-1800 RPM) driveability issue
GRTfast
Re: Low speed (1500-1800 RPM) driveability issue
Post by GRTfast »
BILL-C wrote: Wed Sep 11, 2019 8:01 pm With a light car and 3.25 rear gear, 1500-1800 rpm, and such a large carb, you are still cruising on the idle circuit . You can make 30+ hp before pulling a drop of fuel through boosters if the secondary throttle plate stop screw is opening plates even slightly at idle. It is very common for 1 booster to start pulling fuel before the others, causing light throttle fuel distribution issues. Full throttle fuel distribution has absolutely nothing to do with light throttle fuel distribution. Very common to see the fuel distribution change with rpm and throttle position. Set up a GO-PRO or similar camera over carb and go for a test drive. I'll bet you will be surprised at what you see. Oversized carb and intake ports contribute to problem also.
Interesting, I may do that.
travis
Post by travis »
That cam is listed as 2200-5800 rpm range, just FYI. You’re trying to operate outside of its listed rpm range. 235/249@.050 on a 107 lsa...lots of overlap and low speed reversion there for sure.
Maybe cruise in the next lower gear? :wink:
GRTfast
Post by GRTfast »
Update. Last night I made a temporary divider that works with my open spacer. It definitely made a difference in the right direction, but with the open spacer, there is a tip in stumble that I could not cure with a bunch of different accel pump cam/squirter combinations. It looks like the 4 hole spacer (for throttle response) with a divider filler (like the one Brian M showed) will be the sweet combo. I'll report back once I have all that in place and have the carb tuned. Thanks for the help.
BobbyB
Post by BobbyB »
Can you post a picture of the divider you made?
Post by F-BIRD'88 »
Make or get a combo spacer. (2 holes on the deep side
A oval on the shallow side) that supports your divider.
(Divider attached to combo spacer)
Good effort and progress.
Post by F-BIRD'88 »
Likely a better camshaft for your purpose and driving would be the factory hyd roller cam from the GMPP 502-502 hp crate motor. 226-230 110 LSA 8 deg overlap. @.050
Verses current 28° overlap.
Or another cam like that.
GRTfast
Post by GRTfast »
BobbyB wrote: Thu Sep 12, 2019 8:12 am Can you post a picture of the divider you made?
I will when I take it out, I have a new 4 hole spacer on the way from summit. I made this open spacer out of the 4 hole I had (I have a mill). I milled the spacer open, then milled a couple slots in it that the divider fits into. The divider divides the spacer opening and has a tab that sticks down into the notch in the manifold divider. It's all pretty basic, it was intended as a proof of concept, not as something I would use permanently.
GRTfast
Post by GRTfast »
F-BIRD'88 wrote: Thu Sep 12, 2019 8:46 am Likely a better camshaft for your purpose and driving would be the factory hyd roller cam from the GMPP 502-502 hp crate motor. 226-230 110 LSA 8 deg overlap. @.050
Yeah, sometime soon I need to have Cam King make me a custom bump stick.
murre
Post by murre »
if I did not misunderstand your symptoms. then I had the same problem. the solution was. I taped half the air filter (180 degrees). I try to turn it forward. then backwards. then for fun I turned to one side. to my great surprise, the problem disappeared. it works just as well on the left as the right side. a very easy test to do.
Tuner
Post by Tuner »
GRTfast wrote: Thu Sep 12, 2019 8:08 am Update. Last night I made a temporary divider that works with my open spacer. It definitely made a difference in the right direction, but with the open spacer, there is a tip in stumble that I could not cure with a bunch of different accel pump cam/squirter combinations. It looks like the 4 hole spacer (for throttle response) with a divider filler (like the one Brian M showed) will be the sweet combo. I'll report back once I have all that in place and have the carb tuned. Thanks for the help.
I had this problem, "a tip in stumble that I could not cure with a bunch of different accel pump cam/squirter combinations." a while back and the cure was to completely close the secondary throttles and readjust the primary idle accordingly.
You haven't answered the question, "How much does the intake vacuum increase from the curb idle to the level road cruise at 1500-1800?"
You should try closing the secondary idle mixture screws completely and only using the primary idle mixture screws to set the idle mixture.
I can't imagine any reason to change the camshaft when tuning the carburetor is what to do. Funny how if somebody thinks they are a hammer everything they see is a nail.
bobmc
Post by bobmc »
have you used the carb spacer heatshield like the factory used? I would think the shorter spacer the better. MSD type boxes have been taming race cam idle since the 1970's, I don't think you could foul plugs with the idle settings
ClassAct
Post by ClassAct »
Tuner wrote: Thu Sep 12, 2019 4:20 pm
I'm glad you pointed that out. It's a tuning issue. The OP is making progress and needs to keep moving forward.
Addressing the question you asked is the first step. Once that information is provided, it's will most likely be a simple fix.
GRTfast
Post by GRTfast »
ClassAct wrote: Fri Sep 13, 2019 10:11 am
I will get the vacuum measurement during a test drive this weekend and report back.
GRTfast
Post by GRTfast »
BobbyB
Post by BobbyB »
Nice work. Thanks for posting the picture.
