Ls 3 cylinder walls cracked
sccagt1racer
Post by sccagt1racer » Tue Sep 10, 2019 8:07 pm
Is it common for a ls3 bored to 4.070 to crack the cylinder walls vertically? #3 and #5 . The build is 11.2 to 1. cathedral port trick flow heads, ls6 intake, dry sump 7400 rpm's road race use. 450 hp 445tq at the rear wheels. It also has been losing the ground straps off the spark plugs. I suspect the tune has too much timing. Detonation?
peejay
Re: Ls 3 cylinder walls cracked
Post by peejay » Tue Sep 10, 2019 8:41 pm
The only time I ever lost the ground straps from the plugs, I was way off on the heat range because I didn't know any better, yet. Was running NGK 6-range plugs on an engine that needed -10s.
needforspeed66gt
Post by needforspeed66gt » Wed Sep 11, 2019 7:18 pm
Very uncommon, I see it with the LS7 blocks all the time, but only on one of the cast in place liner blocks if the tune was grossly off and resulted in nonstop detonation cycles. Look in through that water jacket passage and see if there's a crack in the aluminum right behind the cracked sleeve, the LS7 engines almost always crack both...the cylinder pressure spikes blow out the liner and the aluminum support for the sleeve cracks, then the actual liner cracks afterwards.
Nate @steeldustmachine
Engine Machinist
A_VAS
Post by A_VAS » Fri Sep 13, 2019 11:07 am
I've only seen that with LS2/3 blocks if a valve drops or piston chunk gets stuck between piston/head.
not seen it with detonation on engines that I know were detonated....so I'd say that's uncommon.
when I find a cracked one as mentioned, I save the blocks to use for Darton sleeving projects down the road
too lazy to make power w/o boost
sccagt1racer
Post by sccagt1racer » Fri Sep 13, 2019 3:38 pm
I got the engine fully torn down today. 6 out of 8 were cracked. The front cylinders were the only ones that were not cracked. The thrust side of the rod bearings have wear and the rest of the bearing looks normal. excessive detonation. The tune was not correct is what im going with on this one.
exhaustgases
Post by exhaustgases » Fri Sep 13, 2019 6:12 pm
Just curious was this ever a problem with the old factory stock bore SBC I can't ever remember seeing that on one from detonation? So how thick are the cylinder walls? Where all the cracks oriented the same? And how? For and aft? Side to side?
