Thats crazy!
accurately measuring port cross section area
Re: accurately measuring port cross section area
- midnightbluS10
What's crazier is I can do all of that in my head quicker than they can write the first set of numbers to try to explain it all. It's almost as if they're trying to teach kids those shortcuts I do in my head, using math lessons except it don't work like that. Either you get it or you don't, imo.
JC -
Cross section area makes sense for a straight pipe.
What becomes of the effective cross sectional area when the pipe has a bend in it?
My guess is this is why probing air speed is needed in relation to cross section.David Redszus wrote: ↑Tue Sep 17, 2019 12:35 pm Cross section area makes sense for a straight pipe.
How effective, or accurate is probing without an exhaust stub on the port that's the size and shape of the primary pipe used on the engine?GARY C wrote: ↑Wed Sep 18, 2019 12:40 pmMy guess is this is why probing air speed is needed in relation to cross section.David Redszus wrote: ↑Tue Sep 17, 2019 12:35 pm Cross section area makes sense for a straight pipe.
How would you even manage that maneuver?
- Stan Weiss
When you develop your intake port. Do you use a naked port, a port with a radius plate, or use the intake manifold that will be used with the heads?gmrocket wrote: ↑Wed Sep 18, 2019 1:33 pmHow effective, or accurate is probing without an exhaust stub on the port that's the size and shape of the primary pipe used on the engine?GARY C wrote: ↑Wed Sep 18, 2019 12:40 pmMy guess is this is why probing air speed is needed in relation to cross section.David Redszus wrote: ↑Tue Sep 17, 2019 12:35 pm Cross section area makes sense for a straight pipe.
I was speaking about the intake, I only flow the exhaust for sound with no pipe.gmrocket wrote: ↑Wed Sep 18, 2019 1:33 pmHow effective, or accurate is probing without an exhaust stub on the port that's the size and shape of the primary pipe used on the engine?GARY C wrote: ↑Wed Sep 18, 2019 12:40 pmMy guess is this is why probing air speed is needed in relation to cross section.David Redszus wrote: ↑Tue Sep 17, 2019 12:35 pm Cross section area makes sense for a straight pipe.
My guess is if you were going to try to find a way to develop an exhaust port on a flow bench you would need a pipe with probes installed or holes for probes but I would not even know where to start or what you would be looking for.
Same goes for the intake,, with just a clay radius at the opening when probing, how accurate can that be ?GARY C wrote: ↑Wed Sep 18, 2019 4:17 pmI was speaking about the intake, I only flow the exhaust for sound with no pipe.
Sweeping runners on a single plane favor certain areas of the port over another..can't duplicate that kind of flow bias when probing.
Maybe a straight shot intake manifold like a T ram you could actually make up an entry that simulates the intake and probe down that..
But anything else, I think it's a crap shoot
I
It's not hard to make up a piece out of sheet metal and some epoxy or putty
I try to use the intake that will be on the engine,, or at least,, something that simulates the last few inches of the manifold exit.Stan Weiss wrote: ↑Wed Sep 18, 2019 2:23 pmWhen you develop your intake port. Do you use a naked port, a port with a radius plate, or use the intake manifold that will be used with the heads?
Yet it seems the best heads and power per cube seem to come from the guys that focus on air speed and I don't think any of them flow the head with an intake, they size the intake based on mathematical air speed and that is usually marked and measured every inch, they do the same with molds of the head for the best measurement in relation to air speed.gmrocket wrote: ↑Wed Sep 18, 2019 7:30 pmSame goes for the intake,, with just a clay radius at the opening when probing, how accurate can that be ?GARY C wrote: ↑Wed Sep 18, 2019 4:17 pmI was speaking about the intake, I only flow the exhaust for sound with no pipe.
Phil Martin Nascar cylinder head developer has some pretty good info in his interview regarding intake design. viewtopic.php?f=47&t=57582
The easy answer is the CSA should lie on a plane perpendicular to the flow field. The hard part is determining where that is. . . and what to do if the perpendicular surface happens to be not flat.David Redszus wrote: ↑Tue Sep 17, 2019 12:35 pm Cross section area makes sense for a straight pipe.
In general if the bent "pipe" has constant CSA, the plane should meet the pipe walls at 90 degrees. If the bent pipe is straight tapered, the plane should meet the pipe walls at the same angle all around - 90 deg + (taper angle)/2.
Here is another optionGARY C wrote: ↑Wed Sep 18, 2019 4:17 pmI was speaking about the intake, I only flow the exhaust for sound with no pipe.
http://rtstooling.com/
Yes I have seen that, it probably wouldn't be to hard to make but I am not sure what you would be looking for in terms of speed or pressure and you would probably have to do years of dynoing different seat and throat changes to build a data base.HDBD wrote: ↑Sat Sep 21, 2019 10:54 amHere is another optionGARY C wrote: ↑Wed Sep 18, 2019 4:17 pmI was speaking about the intake, I only flow the exhaust for sound with no pipe.
