hoffman900 wrote: ↑Wed Sep 18, 2019 8:13 am
Dr. Andrew Randolph of ECR in his NASCAR Engines 101 lecture said best power is made on the exhaust side when the expansion loss is balance to the pumping loss. In the example he gave, it’s about 20hp for each...
That is very important to note.
Assuming that EVO occurs at about 75 deg BBC, most of the exhaust gas mass has escaped by the time the piston reaches BDC. During this blowdown period, the exhaust valve is far from fully open; but it does not need to be since cylinder pressure is still high.
After BDC, the piston must do the work of pumping the remaining burned gas out of the cylinder.
Andy is absolutely correct in that we want the minimum pumping work required balanced against early opening exhaust pressure loss.
The exhaust side behaves completely different than does the intake side.
