The engines that I am running take out a huge amount of heat from the pistons with the oil squirters. In one engine, we ran the computations on what was needed with going from 1.5mm to 1mm rings while tripling the stock power — guess what, a lot of oil flow was needed! This was with Mahle Motorsports NA help.Roundybout wrote: ↑Tue Sep 13, 2022 7:35 pm How is the heat dissipated from the piston? I thought a majority of it was through the rings. A barrier coating on the top would keep more heat in the chamber (and out the exhaust it goes) there-by the rings wouldn’t be as burdened dissipating the heat from combustion as much. Any coating I think would raise the octane requirement if it’s rejecting heat back into the combustion chamber. Piston squirters also help remove the heat from the piston. I’d be interested in the combo of a coating and squirters as far as power production. Using both would certainly be good for the piston.
I’m Johnny come lately getting interested in an air cooled engine, and it seems to me that as long as I have enough octane, keeping the piston, cylinder heads, and valves cool is going to allow for more reliable power. I wonder if some people are coating EVERYTHING in these air cooled engines?
