SBC Alum Heads
SBC Alum Heads
Anyone have any real data on the Brodix IK 200 heads? Wondering how they would work on a pump gas 406. Was thinking of using a Comp 12-460-8 hyd roller. 600 lift, 244 duration at .050. Lobe separation 110. I always ran Brodix on my BBC in the race car, not much experience with SB stuff.
Re: SBC Alum Heads
Brodix flow numbers have alway been right on the money when tested on my bench , and judging by those numbers those heads in out of the box form should make a solid 525 hp and with a 406 cid motor pull real strong to 6500.
- BrazilianZ28Camaro
Re: SBC Alum Heads
These are good heads for the money.
I built a 355 SBC for a buddy with these heads ported with a similar cam , 10:1 CR and a tunnel ram.
His 69' full trim Chevelle ran 7.4s in the eight mile with a good light under the front wheels.
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
1.38 60' / 4.05 330' / 6.32@111.25mph
NEW BEST ET
Re: SBC Alum Heads
I've had good luck with all the BBC Brodix heads. I was just shocked at the price, pretty cheap I thought.
