Oil drain back
Oil drain back
I am doing a couple of oil drain backs from the heads and i have a remote oil filter with 2 inlets and to outlets can i use one inlet for a return line or will the pressure it back up the line to the head,i only use one inlet and one exit atm or punch a couple holes in the top of the sump.
Re: Oil drain back
Oil drainback lines from the heads should be plumbed to the oil pan. DO NOT USE the ports off the oil filter housing.
Mark Goulette
Authorized Amsoil Retailer
- Dave Koehler
Re: Oil drain back
Mark is correct and you answered your own question.
Your initial idea would plumb a gravity fed line into a pressure fed line.
Yes, it will go the wrong direction and essentially send the pressure to zero.
Re: Oil drain back
Also, gravity alone is not enough to push oil through any worthwhile mesh filter.
Re: Oil drain back
Will a vacuum pump make the problem worse or help with getting the oil back down to the sump?
Re: Oil drain back
Depends. If you suck from a rocker cover, likely worse. If from the valley, better.
Re: Oil drain back
It pulls from the valve cover now but i will do a fitting on the valley plate.Cheers
