Oil drain back
moparian
Oil drain back
Post by moparian » Fri Oct 04, 2019 9:41 am
I am doing a couple of oil drain backs from the heads and i have a remote oil filter with 2 inlets and to outlets can i use one inlet for a return line or will the pressure it back up the line to the head,i only use one inlet and one exit atm or punch a couple holes in the top of the sump.
Coloradoracer
Re: Oil drain back
Post by Coloradoracer » Fri Oct 04, 2019 11:19 am
Oil drainback lines from the heads should be plumbed to the oil pan. DO NOT USE the ports off the oil filter housing.
Mark Goulette
Authorized Amsoil Retailer
Dave Koehler
Re: Oil drain back
Post by Dave Koehler » Fri Oct 04, 2019 12:25 pm
Mark is correct and you answered your own question.
Your initial idea would plumb a gravity fed line into a pressure fed line.
Yes, it will go the wrong direction and essentially send the pressure to zero.
Fuel Injection - Nitrous Charger - Balancing - Nitrous Master software
Re: Oil drain back
Post by MadBill » Fri Oct 04, 2019 8:12 pm
Also, gravity alone is not enough to push oil through any worthwhile mesh filter.
moparian
Re: Oil drain back
Post by moparian » Fri Oct 04, 2019 8:52 pm
Thought that may have been the case ,Cheers guys
moparian
Re: Oil drain back
Post by moparian » Fri Oct 04, 2019 11:39 pm
Will a vacuum pump make the problem worse or help with getting the oil back down to the sump?
Re: Oil drain back
Post by MadBill » Sat Oct 05, 2019 12:14 am
Depends. If you suck from a rocker cover, likely worse. If from the valley, better.
moparian
Re: Oil drain back
Post by moparian » Sat Oct 05, 2019 3:37 am
It pulls from the valve cover now but i will do a fitting on the valley plate.Cheers
