Lobe sep
rocketracer380
Lobe sep
Post by rocketracer380 » Sat Oct 05, 2019 9:02 am
Same cam with narrower lobe sep 108 vs 110 its a small block olds with stock heads and pump gas.any power band difference ?
Carnut1
Re: Lobe sep
Post by Carnut1 » Sat Oct 05, 2019 9:32 am
Easy way to look at lobe center angle. The better the heads the wider the centers can be for the same rpm. So Olds heads are not great the tighter centers will probably work better except maybe the very top end where the wider lc will be equal. With only 2 degrees difference in lc the power difference will not be that much. I would try the tighter lc.
631-816-4911
9:00am - 9:00pm EST
