CNC Heads?
- Dave Koehler
Re: CNC Heads?
You are going to need to provide more info. Generalities don't flow well around here.
Brand, model, etc. for a start.
Re: CNC Heads?
CNC in itself simply means that all the ports will be the same but, has nothing to do with how good the ports are designed.econo racer wrote: ↑Mon Oct 14, 2019 7:47 am Has anyone ever looked at or tried running a set of CNC imported SBC heads?
Where did that model intake and exhaust port come from ...?
Re: CNC Heads?
I've run my program in about 4 pallets of the ProHeader Dart copy.
Zero issues. Makes 550 on a 383 pump gas and 650+ on a 383 drag engines.
Kept it small and sake, has all it can do to break 300cfm.
Re: CNC Heads?
Doesnt take much to get those over 300 (same one chad uses probably)
x2 CNC doesnt mean its good..or bad. Figured it was a matter of time before those started floating around.
Played with a set of those and #s were strong everywhere pleasantly surprised.
Re: CNC Heads?
Everybody talks about CNC heads, what usually I ask is, who did the original porting you are coping, or did you just tell the computer program to make them a certain percent larger? Just wondering why don't the sellers of CNC porting advertise who did the work the program is copying? Seems they might get more business? I port my own heads, I'm sure I leave HP on the table, but I just like the challenge of doing my own work. I have checked several CNC heads on my bench, most flow well, but the velocity is almost always a lot lower compared to the porting I do. And I just do a few engines a year so I don't claim to be an expert. Also seen some failures because the program takes out too much material, causing cracks and leakage as well.
Re: CNC Heads?
Pretty stuff sells....seems the resale is getting whored out, perhaps a twist to bumps sales Id guess.
Re: CNC Heads?
My import chamber.
With mine, the same effort went into the design as everything else, just use a different step over for machine time to keep the cost down.
- midnightbluS10
Re: CNC Heads?
Tell the computer to make it a certain percentage larger? Are cnc machines now using AI to CNC? You can't just stick a head in, type in that you want this hole/port this much larger and let it work. That's not how cnc works. If there's a program to run, there's a pattern to follow, and someone programmed that pattern. No matter what it's doing. Someone programmed it to do that. You don't just stick parts in and tell it to arbitrarily a pick space and remove material of its own choosing, which is how you've explained it, it seems. It doesn't just take material out anywhere.rebelrouser wrote: ↑Tue Oct 15, 2019 12:44 pm Everybody talks about CNC heads, what usually I ask is, who did the original porting you are coping, or did you just tell the computer program to make them a certain percent larger? Just wondering why don't the sellers of CNC porting advertise who did the work the program is copying? Seems they might get more business? I port my own heads, I'm sure I leave HP on the table, but I just like the challenge of doing my own work. I have checked several CNC heads on my bench, most flow well, but the velocity is almost always a lot lower compared to the porting I do. And I just do a few engines a year so I don't claim to be an expert. Also seen some failures because the program takes out too much material, causing cracks and leakage as well.
The cnc machine only executes motions that are programmed into the machine. And the whole "who are you copying" isn't a good question to ask. You ask who did the master that the program was based on. It sounds like you're trying to throw shade if you ask "who are you copying".
Last edited by midnightbluS10 on Tue Oct 15, 2019 6:00 pm, edited 2 times in total.
JC -
Re: CNC Heads?
You can tell it I want the throat .020 smaller or I want less step over on the roof.midnightbluS10 wrote: ↑Tue Oct 15, 2019 5:54 pmTell the computer to make it a certain percentage larger? Are cnc machines now using AI to CNC? You can't just stick a head in, type in that you want this hole this much larger and let it work. That's not how cnc works. If there's a pattern to follow, someone programmed that pattern.rebelrouser wrote: ↑Tue Oct 15, 2019 12:44 pm Everybody talks about CNC heads, what usually I ask is, who did the original porting you are coping, or did you just tell the computer program to make them a certain percent larger? Just wondering why don't the sellers of CNC porting advertise who did the work the program is copying? Seems they might get more business? I port my own heads, I'm sure I leave HP on the table, but I just like the challenge of doing my own work. I have checked several CNC heads on my bench, most flow well, but the velocity is almost always a lot lower compared to the porting I do. And I just do a few engines a year so I don't claim to be an expert. Also seen some failures because the program takes out too much material, causing cracks and leakage as well.
I have had many of my ports shrunk .050 on all walls. Then hand finish per application
Re: CNC Heads?
I assume someone in China probably copied an AFR or Brodix head.midnightbluS10 wrote: ↑Tue Oct 15, 2019 5:54 pmTell the computer to make it a certain percentage larger? Are cnc machines now using AI to CNC? You can't just stick a head in, type in that you want this hole/port this much larger and let it work. That's not how cnc works. If there's a program to run, there's a pattern to follow, and someone programmed that pattern. No matter what it's doing. Someone programmed it to do that. You don't just stick parts in and tell it to arbitrarily a pick space and remove material of its own choosing, which is how you've explained it, it seems. It doesn't just take material out anywhere.rebelrouser wrote: ↑Tue Oct 15, 2019 12:44 pm Everybody talks about CNC heads, what usually I ask is, who did the original porting you are coping, or did you just tell the computer program to make them a certain percent larger? Just wondering why don't the sellers of CNC porting advertise who did the work the program is copying? Seems they might get more business? I port my own heads, I'm sure I leave HP on the table, but I just like the challenge of doing my own work. I have checked several CNC heads on my bench, most flow well, but the velocity is almost always a lot lower compared to the porting I do. And I just do a few engines a year so I don't claim to be an expert. Also seen some failures because the program takes out too much material, causing cracks and leakage as well.
Joe Facciano
Re: CNC Heads?
This ^midnightbluS10 wrote: ↑Tue Oct 15, 2019 5:54 pmTell the computer to make it a certain percentage larger? Are cnc machines now using AI to CNC? You can't just stick a head in, type in that you want this hole/port this much larger and let it work. That's not how cnc works. If there's a program to run, there's a pattern to follow, and someone programmed that pattern. No matter what it's doing. Someone programmed it to do that. You don't just stick parts in and tell it to arbitrarily a pick space and remove material of its own choosing, which is how you've explained it, it seems. It doesn't just take material out anywhere.rebelrouser wrote: ↑Tue Oct 15, 2019 12:44 pm Everybody talks about CNC heads, what usually I ask is, who did the original porting you are coping, or did you just tell the computer program to make them a certain percent larger? Just wondering why don't the sellers of CNC porting advertise who did the work the program is copying? Seems they might get more business? I port my own heads, I'm sure I leave HP on the table, but I just like the challenge of doing my own work. I have checked several CNC heads on my bench, most flow well, but the velocity is almost always a lot lower compared to the porting I do. And I just do a few engines a year so I don't claim to be an expert. Also seen some failures because the program takes out too much material, causing cracks and leakage as well.
The copies we use are an exact copy of the Dart pro 1, I have had them side by side to compare and they have the same little marks, nicks etc everywhere.
I see a lot of hand porters poo poo cnc porting, thats fine, it interferes with there income, it is expected.
Chad, the wide step over on your intake ports is to make it cheaper eh?? Yeh sure. I do like your work.
Re: CNC Heads?
I have not seen a picture of porting out of the box looking like Chads. His looks like art. I have a set of Canfield 195's with 205-160 valves. I want to step up soon to something possibly making at least 40 more hp.
