You've got one bad rod journal, but are the mains and the other rod close enough you would want to run them standard?
Can't say what you'd find for the Gutser, but building obsolete engines for which bearings are NLA, about once a year I spend way too much time in bearing catalogs finding the closest available bearing and then sizing the crank journal and the rod bore to that spec.
FWIW, I was always hesitant to narrow a bearing shell, but after a conversation with a Clevite engineer convinced me it shouldn't be a problem, that has occasionally been the solution.
X2 for Adney. Just don't be in a time crunch. Adney is so good, he's got a backlog.X2, call Adney Brown at Performance Crankshaft. He does all kind of repairs, welding and hard chroming.
If he says he can do it, it will be right.
