Limits of splashzone or Belzona?
Never used either, useage would be for busting through heads or intakes whats your experience?
Til I learn to weld have to be conservative and use JB which has been fine so far but from reading on the ones listed in title Im curious
Whats your experience show?
Will either hold up to a cooling jacket and the pressures/temps?
Re: Limits of splashzone or Belzona?
Belzona search results limited to the Speed-Talk site:
https://www.google.com/search?q=site%3A ... belzona%22
Splashzone search results limited to the Speed-Talk site:
https://www.google.com/search?q=site%3A ... ashzone%22
I am not trying to be a jerk. There is a lot of information on this site that has come from people that are no longer alive. They will not be able to respond to your current question.
I have used Belzona to totally rebuild walls in Intake Manifolds , in regards to iron heads I have used it to build up Intake port floors with a thickness of some 1/4" or more.
In regards to repairing cylinder head port wall blow thru's I have used it to repair a hole of about 1/8", if I needed to repair a hole that is larger I would take it to a shop that can pressure test heads and have them use a pour in sealer to act like a Condem.
There are a baker's halfdozen different Belzona " Metal Repair / Rebuilding " products.
https://www.belzona.com/en/products.aspx
https://www.belzona.com/en/products/pur ... epair.aspx
Some have pretty limited temperature resistance when "immersed" in an unidentified liquid.
1111 Super metal 49 °C (120°F) immersed, 200°C (392°F) dry
The 1511 is about the only one with good "immersed temperature resistance." 160°C (320°F) immersed, 210°C (392°F) dry
Last edited by Dan Timberlake on Thu Oct 24, 2019 9:26 am, edited 1 time in total.
I was given a pair of iron SBC heads that were misdrilled when doing the screw-in studs, some moron drilled all the way through the floor of the coolant passage and broke through to the intake ports. Sounds like 1511 would be the only thing suitable here?
DON'T PANIC
For a hole like you have now ( about .375" ) I would want to pre- heat and braze those closed.
What do you use to braze them with?
Thanks for the feedback I did google...can only read so many guesses before I lose patience lol
? Of will it hold up to a cooling jacket if I bust through was the main one. Bowl area..one day Ill have to learn to weld and buy a sonic tester if Im going to get serious about hacking.
I think A and B is kinda mickey mouse, used to use it to fix cracks in swimming pools til the injectable stuff came out. That A and B falls apart over time.
It's not the full diameter exposed, the C/L of the stud location is about directly over the vertical port wall so only a portion of the drilled hole broke through in the upper corner. The location is REALLY difficult to get at.
Being rational about it they should probably just be thrown away, if the repair were to fail pressurized coolant flooding an intake port would result in some impressive carnage.
DON'T PANIC
What magical pipe thread size will fit through a 7/16-14 hole at the top and yet seal up a .375 hole at the bottom?
DON'T PANIC
If I understand the issue correctly, how about threading the hole with a bottoming tap and running in a suitably coated 7/16" set screw, short enough to allow subsequent installation of the stud?
1/8 smart alec. You can stack sizes, or put a time-sert over it. Lock and stich repair pins are the same threads per inch and taper as 1/8 pipe, like a pipe plug that just keeps going.turbo camino wrote: ↑Thu Oct 24, 2019 2:51 pm What magical pipe thread size will fit through a 7/16-14 hole at the top and yet seal up a .375 hole at the bottom?
