Not in this case. Reliability was more of a factor. I assume this is a hydraulic roller street/strip performance application, not a race-only application.David Redszus wrote: ↑Mon Oct 28, 2019 11:07 pmMike,CamKing wrote: ↑Sat Oct 26, 2019 1:23 pmNo. Those opening and closing numbers are for a cam that's 242 on the intake, and 288 on the exhaust.Knight rider wrote: ↑Fri Oct 25, 2019 4:38 pm
Thanks so yours has more duration on the exh ? Cheers
Edit
So is this correct for your specs cheers
It looks like you used the .050" intake duration for the intake numbers, and the .006" Intake duration for the exhaust numbers.
Here's the opening and closing numbers for my cam.
At .050" Lobe Lift
IVO: 14 BTDC
IVC: 48 ABC
EVO: 56 BBC
EVC: 10 ATDC
Overlap = 24
At .006" Lobe Lift
IVO: 37 BTDC
IVC: 71 ABC
EVO: 79 BBC
EVC: 33 ATDC
Overlap = 70
Do you factor in valve diameter into the lift determination?
Cam card info
Re: Cam card info
Re: Cam card info
I messaged SCM this is the closest he has, probably more overlap than I was looking at but not sure ?
Re: Cam card info
That one would put peak HP around 6,400rpm.Knight rider wrote: ↑Tue Oct 29, 2019 1:24 pmI messaged SCM this is the closest he has, probably more overlap than I was looking at but not sure ?
You may want to ask them if they dyno'd one of those cams in an engine your size, and see if they'll let you see the results, to see if it'll work for your application
