Cam card info
Cam card info
Where does 1 find camshaft specs other than the usual @50, max lift, LSA etc
I'm trying to compare cams but can't seem to find opening and closing info or ramp rates etc is this become a secret now, compcams used to have more info on there site but not now. I'm mainly looking a lunatic and Howard cams at the moment cheers
Re: Cam card info
Maybe I should let you guys pick me a cam- this is what I'm looking at
Engjne 393 Cleveland
Heads 3v 235cc flow 280@600
11.5-1 comp
4-1 Pacemaker 1 3/4 headers
3.89 diff
Stall TC 3000 to 3500rpm still working on the auto
Custom intake
Holley terminator EFI
ZG Fairlane 3500lbs
Street/strip
https://www.howardscams.com/hydraulic-r ... -230335-10
https://www.lunatipower.com/voodoo-retr ... 2-300.html
This is what I have now
https://www.compcams.com/magnum-245-245 ... ductattach
11.5-1 comp
3.89 diff
Custom intake
ZG Fairlane 3500lbs
Street/strip
Re: Cam card info
Comp's new site sucks... Here is there lobe catalog if that helps.
https://www.carid.com/images/comp-cams/ ... atalog.pdf
Re: Cam card info
What RPM do you want to make peak HP at ?
Re: Cam card info
I had a 396 solid roller motor but trick flows I’ll see if I still have the cam card might get you some ideas, shop that did my machine work specced it out. It was pretty big lift iirc.
Re: Cam card info
Thanks for the replys so far.
Max hp rpm 6000 but I can shift at 6500 or so but from what I've seen its actually faster or as fast to shift earlier.
What I'm thinking I'd like is a cam with less overlap but with the same lift or a little more, I did find the specs on the compcam I have
Exh closes 38atdc intake opens 48btdc
Exh opens 86bbdc intake closes 78abdc
244@50 and valve lift 612
In my mind I'm thinking I'd see more benifits from delaying the intaking opening and maybe increasing the intake closing with the intake manifold I have which has straight tall runners ? More ram effect ? Cheers
And yes compcams new site is far from ideal
Re: Cam card info
Here's what I recommend.
Cam# F351c, HR74365-75365-110
288/292 @.006"
242/246 @.050"
.365"/.365" Lobe Lift
110 LSA
107 ICL
288/292 @.006"
242/246 @.050"
110 LSA
107 ICL
Re: Cam card info
That's one of our custom grinds.
Re: Cam card info
Thanks, don't know how I'd go getting one of yours being Down under and also the time frame it might take, but i'll think about the options would be nice to have a custom cam cheers
Is there options to have one of my cam's I ready have reground over here to your specs - happy to pay for the service just don't know if that's a done thing ?
Re: Cam card info
Just see if you can find a cam as close to my specs as possible.
We ship cams to Australia all the time, but it's expensive.
Check with SCM Engine Development in Ballarat, and see if they have something close.
Re: Cam card info
Re: Cam card info
No. Those opening and closing numbers are for a cam that's 242 on the intake, and 288 on the exhaust.Knight rider wrote: ↑Fri Oct 25, 2019 4:38 pm
Thanks so yours has more duration on the exh ? Cheers
Edit
So is this correct for your specs cheers
It looks like you used the .050" intake duration for the intake numbers, and the .006" Intake duration for the exhaust numbers.
Here's the opening and closing numbers for my cam.
At .050" Lobe Lift
IVO: 14 BTDC
IVC: 48 ABC
EVO: 56 BBC
EVC: 10 ATDC
Overlap = 24
At .006" Lobe Lift
IVO: 37 BTDC
IVC: 71 ABC
EVO: 79 BBC
EVC: 33 ATDC
Overlap = 70
Re: Cam card info
CamKing wrote: ↑Sat Oct 26, 2019 1:23 pmNo. Those opening and closing numbers are for a cam that's 242 on the intake, and 288 on the exhaust.Knight rider wrote: ↑Fri Oct 25, 2019 4:38 pm
Edit
At .050" Lobe Lift
IVO: 14 BTDC
IVC: 48 ABC
EVO: 56 BBC
EVC: 10 ATDC
Overlap = 24
At .006" Lobe Lift
IVO: 37 BTDC
IVC: 71 ABC
EVO: 79 BBC
EVC: 33 ATDC
Overlap = 70
Thanks for info great stuff cheers
Re: Cam card info
Mike,CamKing wrote: ↑Sat Oct 26, 2019 1:23 pmNo. Those opening and closing numbers are for a cam that's 242 on the intake, and 288 on the exhaust.Knight rider wrote: ↑Fri Oct 25, 2019 4:38 pm
Edit
At .050" Lobe Lift
IVO: 14 BTDC
IVC: 48 ABC
EVO: 56 BBC
EVC: 10 ATDC
Overlap = 24
At .006" Lobe Lift
IVO: 37 BTDC
IVC: 71 ABC
EVO: 79 BBC
EVC: 33 ATDC
Overlap = 70
Do you factor in valve diameter into the lift determination?
