.080" larger journal size only gives you .040" less lobe to rod clearance so the two together nets you .010" more clearance.BLOCKMAN wrote: ↑Wed Oct 30, 2019 6:28 pm2.000 rod only gives you .050 more clearance then the 2.100 its not the full .100 its half of that been there done that.Charliesauto wrote: ↑Wed Oct 30, 2019 4:48 pm1.868" journal with around.425"-.430" lobe lift should be 1.000" base circle without out any further reduction. More LL than around .430" will be less than 1.00"base circle .
Based on the info you provided, his combo actually adds up. .100" smaller rod journal and .080" larger cam bearing journal.
speaking of SBC blocks
Re: speaking of SBC blocks
It's the H beam rod like cnc-motorsports has in that link. Summit has the wrong pic for that part number.77cruiser wrote: ↑Wed Oct 30, 2019 4:31 pm These? https://www.cnc-motorsports.com/callies ... 50185.html
Summit has I beams https://www.summitracing.com/parts/cpi-u16101/
They do fit with a 3.875 stroke and a BBC cam journal.
Of course a raised cam tunnel would be better.
Randy
