Valve rotators
travis
Valve rotators
Post by travis » Thu Oct 31, 2019 5:44 pm
I’ve got a set of heads with intake and exhaust rotators. For a very mild under 5000 rpm build where longevity is more important than outright power, are the rotators a bad idea? Spring pressure will be a bit higher than stock but nothing crazy (hft application). Do the rotators still work properly with a little more spring pressure?
Also...are the valve locks different with the rotators?
jed
Re: Valve rotators
Post by jed » Thu Oct 31, 2019 6:49 pm
Most cam company's say don't use them with performance cams. However I have seen them used with
mild performance cam with no apparent problems. I would not use them.
Valve locks are the same
PRH
Re: Valve rotators
Post by PRH » Fri Nov 01, 2019 10:03 am
The story I heard is...... not needed with unleaded fuel.
True or not? No idea.
But...... I have seen way more failed rotators than retainers....... and none of the common modern gas powered stuff seems to use them anymore.
I usually get rid of them myself.
Dan Timberlake
Re: Valve rotators
Post by Dan Timberlake » Fri Nov 01, 2019 12:47 pm
what heads ? what valve seats?
Cubic_Cleveland
Re: Valve rotators
Post by Cubic_Cleveland » Sat Nov 02, 2019 4:30 pm
What are you guys using when getting rid of exhaust rotators on SBC heads which have a corresponding taller spring installed height?
Walter R. Malik
Re: Valve rotators
Post by Walter R. Malik » Sat Nov 02, 2019 5:42 pm
Lots of companies offer a .100" taller free height 1.260" O.D. valve spring.
Although, some Chevy heads use a shorter spring on the exhaust side when using the rotator.
Cubic_Cleveland
Re: Valve rotators
Post by Cubic_Cleveland » Sat Nov 02, 2019 6:43 pm
Thanks Walter
