Pros/Cons of using aluminum ring harmonic balancer?
shoedoos
Re: Pros/Cons of using aluminum ring harmonic balancer?
Post by shoedoos » Mon Nov 04, 2019 6:16 pm
^^^^^ is this done at time of balancing?
Rick!
Post by Rick! » Mon Nov 04, 2019 6:27 pm
Warp Speed wrote:
Mon Nov 04, 2019 6:10 pm
shoedoos wrote:
Mon Nov 04, 2019 6:01 pm
any chance you can educate me on how ATI "tune" a damper?
Typically with encoders on the crank measuring twist.
By varying o ring design, number and durometer, along with diameter for a given application and rpm.
That's the how. The "why" is that every crank has a torsional 1st mode (resonant frequency) somewhere in the operating rpm of the engine and the tuned damper minimizes the angular deflection that happens. The smaller engines I dealt with deflect around 3-6 degrees. Some nitro hemi folks say that the crank deflects around 20 degrees during running which then the cam guy has to account for in the grind.
Cranks are made of stiff pieces (crankpins) and not as stiff pieces, namely the rod pins and pork chops and when put together they will have a spot between the snout and rear flange that is susceptible to twisting. Sometimes the twisting happens near the same time a bending frequency is excited but that's not very often. (A bending mode that lives for any amount of time in a crank is a really bad thing. If you find the thread where the sbf crank broke you can see the beach marks are straight across the fracture which means nearly 100% bending failed it.)
In simple terms, the heavier the balancer and clutch/drivetrain (think inertia), the lower the torsional resonant frequency and vice versa. The "balance" is inserting the resonant frequency where it's only a "pass through" and spends little no time there.
exhaustgases
Post by exhaustgases » Mon Nov 04, 2019 6:54 pm
The harmonic balancer or what some call a damper, balances out most of the undesirable crankshaft torsional vibrations. The rigidity of the crankshaft is the main factor that will determine what the balancer tuning (/ weight of an oem rubber isolated damper ring) is, since it is the crankshaft that is torsionaly flexing. Crankshaft balance is a different subject, engine has to be running for torsional vibration measurements.
Warp Speed
Post by Warp Speed » Mon Nov 04, 2019 7:39 pm
On a running engine.
Warp Speed
Post by Warp Speed » Mon Nov 04, 2019 7:45 pm
Yep! ^^^^^
Bending can be a bad bad thing, and very hard to accurately measure! #-o
shoedoos
Post by shoedoos » Mon Nov 04, 2019 8:04 pm
sooooooooo.....in the case of ATI.....you buy one of their balancers, you build engine, you put it on dyno, call ATI, they come along and tune their balancer? Or? Do you build engine without balancer, ATI come along while you dyno without said balancer and they measure to tune a balancer afterward?
modok
Post by modok » Tue Nov 05, 2019 2:23 am
If the rotational mass of the inertia ring is far less than a steel one, then heck no.
Also in most cases an aluminum hub also gets the "heck no"
An aluminum hub CAN work, however it is unlikely that you can simply replace a steel hub with an aluminum one, because there isn't enough space engineered into the engine to do so. Not only will it need to be larger contact areas to have the same strngth, but it will also need a steel sleeve if a seal rides on it.
