mahle piston failure
sccagt1racer
Post by sccagt1racer »
what is your assessment of this piston. Looks to me they got to close to the ring land with the valve relief. There is 2 others that broke the top of the piston off in the same spot. this one was on the verge of breaking.
gruntguru
Re: mahle piston failure
Post by gruntguru »
Gas ported top ring! That hole looks like it was there out of the box. If that's what it is, there won't be any questions about warranty.
af2
Post by af2 »
I am on my phone and didn't see anything that resemble a hole?
GURU is only a name.
sccagt1racer
I zoomed and rotated the picture
engineguyBill
Post by engineguyBill »
Looks like the piston has been subjected to way too much heat, which has actually melted the top of the piston adjacent to the valve relief. Look for detonation and preignition.
Bill
SAE Member (30 years)
digger
Post by digger »
I've seen valve relief pockets in a much more precarious position live perfectly fine with a good tune
gruntguru
Post by gruntguru »
I suggest some careful measurements to determine the proximity of the valve relief to the ring groove. Looks too close to me.
Mark O'Neal
Post by Mark O'Neal »
Tune up.
superpursuit
Post by superpursuit »
I would also look for symptoms of the top ring butting.(shiny ends, etc.) If the rings are butting then the weakest part of the piston will break first.
Allan.
Tuner
Post by Tuner »
Mark O'Neal wrote: Mon Nov 04, 2019 11:51 pm Tune up.
Yup. Looks to me like some preignition was going on, followed by some detonation. Too hot a plug or some funky fuel.
ProPower engines
Post by ProPower engines »
X2
They do not stand up well when the tune is off. Yes they are close but when running correctly with a really good tune
they will live a long and happy life. Step over that edge and poof burnt piston.
While all pistons are not created equal those look like a common power pack piston. I have seen import guys have
the same issue and moving the top ring down will give a bit more area to dissipate heat but again if the tune is off
Poof
Geoff2
Post by Geoff2 »
Where the crack is. To me, it looks like the pressure from the burning A/F has pushed against the wall of the valve relief, where the metal is thin, & this has caused the crack.
Tuner
Post by Tuner »
Until 0'Neal gets around to making investment cast steel pistons you can simply consider aluminum pistons are just a reciprocating fuse.
Truckedup
Post by Truckedup »
engineguyBill wrote: Mon Nov 04, 2019 9:30 pm Looks like the piston has been subjected to way too much heat, which has actually melted the top of the piston adjacent to the valve relief. Look for detonation and preignition.
I'm familar with pre ignition damage on air cooled bike engines...it usual occurs in the center of the piston, very suddenly,like just a few cycles...But on that piston, the off center area that is damaged may be the weak point....
This is typical pre ignition damage...
Protech Racing
Post by Protech Racing »
Long term detonation . If the ring gaps are all lined up, it has run for a while with light detonation.
