347 Ford Sniper EFI cam specs
JES
Post by JES » Thu Nov 07, 2019 7:03 pm
Hello gentlemen.
I am looking for ideas on camshaft specifications for a 10 to 1 347 build. 57 Ford Fairlane 3500lb ?
Toploader 4 speed with 325 rear gears. Of course the customer wants as much of a Lopey sound as he can get but also wants it to start and run for everyday driving. The plan is for Sniper EFI system. The engine will have flat top pistons with ProMaxx aluminum heads. The camshaft needs to be hydraulic flat tappet for this application. 1.6 rockers.
THANKS
CamKing
Re: 347 Ford Sniper EFI cam specs
Post by CamKing » Fri Nov 08, 2019 11:29 am
Cam it to perform, then use the EFI tuning to make it lopey at idle.
The biggest I would go, is a 224/228 @.050", .528"/.528", on a 110 LSA.
My part# is F351w, H70330-71330-110
JES
Post by JES » Fri Nov 08, 2019 7:51 pm
Thanks Mike
