What would you do if your motor was built like this?
Krooser
Post by Krooser »
Got a buddy who crews on his nephews Sprint car team.
This past season they struggled with their SBC not performing up to snuff.
They took it to another builder and look what they found...ouch.
Dan Timberlake
Re: What would you do if your motor was built like this?
Post by Dan Timberlake »
Did it pull to the left under hard acceleration?
Steve.k
Post by Steve.k »
Had the valve clearance set tight at least.
BlitzA64
Post by BlitzA64 »
I bought one from a "Friend" a couple years ago, damn near the same thing. "Dyno tuned" as well. Luckily I caught it before ever using it when I decided to do a leak down and it was like it had no valves at all
turbo camino
Post by turbo camino »
edit: unrelated
DON'T PANIC
Dave Koehler
Post by Dave Koehler »
ehhhh, while humorous I don't think those 2 photos are related.
Dave Koehler
Krooser wrote: Tue Nov 19, 2019 12:02 pm Got a buddy who crews on his nephews Sprint car team.
Some people really go to extremes so as not have to rebalance.
Krooser
Post by Krooser »
They have a hunch the last guy to touch it took their good heads and installed similar but different heads. Big name northeast builder.
Curtis Mc
Post by Curtis Mc »
Here is a "way out there" theory - what if those pistons were in holes where the crew chief knew they may get pumped? It's been known to happen...
novafornow
Post by novafornow »
Raise hell. Not sure what can be proved legally since it was run, but make some noise about the shop to help the next guy.
lefty o
Post by lefty o »
if those arent the pistons that were supplied to the engine builder, and they have suspicion he swapped heads, well i have a short temper and id probably knock the guys teeth out.
Dave Koehler
Since it's a sprint car it must be MFI. Add some nitro but increase the nozzle size on the flat top holes by 10%.
I like the pump checked theory.
dannobee
Post by dannobee »
Curtis Mc wrote: Tue Nov 19, 2019 2:38 pm Here is a "way out there" theory - what if those pistons were in holes where the crew chief knew they may get pumped? It's been known to happen...
I've known "some" people who would do that, along with some strategically located roll bar tubes to "help" the official choose certain cylinders. :shock:
Krooser
Post by Krooser »
410 sprint on mechanical injection. No compression rules.
The engine rev'd effortlessly last season... this year it choked down to 8200-8400. It was their long track motor but could not keep up this year.
I guess I'd be sitting in front of their shop the morning after I found this but they have been pretty cool about the whole deal. Might have a different plan on dealing with the guy. I was told this gshop is a big time deal with lots of top name customers.
tenxal
Post by tenxal »
Got to be way more to the story. :wink:
