Do you know if they had those on both sides?Kevin Johnson wrote: ↑Wed Nov 20, 2019 12:09 pm I think the hot rodder needs to carefully study the design and execution of the slots. Haphazard attention to detail will yield haphazard results. Below are two Honda piston and rod assemblies. In "a" the oil is aimed under the piston; in "b" it is sprayed on the cylinder walls.
A pic of a Mazda one here, it's got one on each side pointing at each way.
So Kevin, for 50 points; bore or piston?
Interestingly that series of engines also had piston squirters in the block, 4 pin oilers per side (of piston) and really tight bearing clearances. Yet after X amount of miles the oil control rings got gummed up, stuck together and they started using oil really heavily. The owners often never noticed so many of them ran completely out of oil and were scrapped.
