So I was browsing for info on tumble and swirl and I came across this graph
The accompanying article can be found here
https://www.semanticscholar.org/paper/S ... 6753129610
And the text accompanying the graph was
So assuming you aren't indexing for clearance, it may be that indexing the plugs shows gains sometimes is not due to pointing the flame in the right/wrong spot, but because the plug is at some orientation to charge motion at firing time. It's worth noting that that graph (assuming 3000rpm) represents about 2 degrees of crank motion. It's also worth noting that unless you're 180 degrees out you're probably close enough. Either way next time I index plugs it will probably be on a 4v engine with zero swirl, so I've got an easy job of getting it right.A. Spark Plug Orientation and Effect on Lean Limit
Systematic experimentation by both Ziegler et al. [14] and Anderson and Asik [15] have shown a heavy influence on spark plug orientation to mean flow direction. Ziegler concluded that a crossflow orientation (figure 1) of the spark plug leads to the largest development of flame growth, as demonstrated in figure 2, and also the widest lean limit range. Anderson and Asik’s experiments appeared to mirror that or Ziegler, concluding that a 90◦ angle is more beneficial than a downstream orientation, additionally finding that ignition can be improved with a higher flow velocity over the spark plugs. Indeed, Nagayama et al. [18] showed how the misfire limit could be improved with the introduction of swirl. This section reviews the impact on rotating flows in the combustion chamber, pertaining particularly to flame propagation, spark plug considerations, lean limit and cycle-by-cycle variations.
