Page 2 of 2
Re: Stuck headstuds in aluminum block
Posted: Wed Nov 27, 2019 10:55 am
by n2xlr8n
I learned the acetone+ATF trick here a while back and it's never failed me. Occasionally I'll add heat with it.
Now I have to remember the 300A welding lead trick.
Posted: Wed Nov 27, 2019 10:29 pm
by rebelyell
Alum !
For millennia, females have used alum to shrink the volumetric profiles of their "Lady Bits" ... so, once done with the steel ???
https://serrestick.com/blogs/news/let-s ... nal-health
Posted: Wed Nov 27, 2019 11:54 pm
by Joe-71
Sometimes with aluminum, you need to tighten the stud first. Double nut, torque +10 lb, and then try to remove. Seems to be a case of not installing the stud hand tight and then back out 1/4 turn. Joe-JDC
Posted: Thu Nov 28, 2019 3:53 am
by Momus
Leftcoaster wrote: ↑Wed Nov 27, 2019 1:58 am
Firmly connect a ~300amp arc welder's leads to block and stud respectively, switch on for 10s then check leads, clamps, and stud temperatures
Try tightening then loosening the stud - - repeat 10s applications if the stud doesn't move and heat isn't excessive
The more corrosion around the thread the greater the resistance and the hotter that area becomes
An old time ZA mechanic swore this method was the only cure for Alfa 4cyl engines run without antifreeze
Head studs on those all ali engines pass through a common coolant jacket and into the block
And I always thought those diabolical Alfa studs were cast in.
Posted: Fri Nov 29, 2019 3:33 am
by Caprimaniac
Baprace wrote: ↑Wed Nov 27, 2019 6:58 am
Caprimaniac wrote: ↑Tue Nov 26, 2019 6:20 am
Got this SBF alu Block. 1/2" studs won't come out. Outer studs, maybe water seeped in, or? Middle Three worst.
Tried two nuts counterbound, no Luck. Going to try heat. Any other suggestions?
Mayby just leaving the studs alone would be the best decision, once you fu%k it up you have alot bigger problem , JMO
Certainly agree.... But; the Block is to be bored, and I figure the studs gotta go? OR?
In for a plate hone, and then they need to go on...
I'll grab a can of acetone & head for the shop tomorrow. Will see how much damage I'll manage to do.
Happy motoring!
Posted: Fri Nov 29, 2019 11:55 pm
by Baprace
Caprimaniac wrote: ↑Fri Nov 29, 2019 3:33 am
Happy motoring!
Capri , any one have a Sunnen CK-10 hone machine near you ? That machine will hone .030 faster than you can bore it and the studs should not be a problem.
Posted: Sun Dec 01, 2019 7:43 am
by Caprimaniac
The shop has a Sunnen, not sure what model, though.
One stubborn sucker left....
All came out good, no threads gone, which is great.
However: holes are blind. And there has been water there...
I have always been sceptical about this: In alu block the sleeves stand proud, how much? 0,05mm?, and what happens in a cold engine: will the gaskets really seal up so water and oil stay where they should be? I don’t know...
Maybe small beads of silicone around the water holes?
Posted: Sun Dec 01, 2019 12:11 pm
by Kevin Johnson
Caprimaniac wrote: ↑Sun Dec 01, 2019 7:43 am
If you need them, I can look up the liner protrusion specs for the Renault alloy blocks with iron wet liners. They later switched to an o-ring seal.
Posted: Sun Dec 01, 2019 3:07 pm
by tenxal
Caprimaniac wrote: ↑Sun Dec 01, 2019 7:43 amAll came out good, no threads gone, which is great. However: holes are blind. And there has been water there...
Make sure there is a decent chamfer around the stud.
Posted: Sun Dec 01, 2019 4:54 pm
by shoedoos
for future reference the "old" melted candle wax down the threads works effectively as well....
