Education time....what were these used for?
First time I have seen one of these, anyone care to educate on their usage pros/cons?
https://www.ebay.com/itm/L-A-BILLET-3-7 ... SwO0Vd1bd8
Re: Education time....what were these used for?
Wow that is wild! It looks like the pins are split roughly the same as a 90 degree V6 gets split to make it even fire. Except... wow, that is wild.
It looks like 1/3/5/7 would all be retarded relative to the other bank, or rather 2/4/6/8 would be advanced. So, thinking this out, with a standard cam the firing order would be
1-8--4---3-6---5--7-2---1-8--4---3-6---5--7-2---1.....
Maybe an attempt to break up the firing order for more acceleration on slick tracks without going to something that would have lots of vibration problems?
Did they ever make a narrow angle SBC block? That crank in say a 60 degree block would be even fire, although I can't say I'd ever heard of anyone doing it...
Possibly for exhaust tuning without the flat plane??
Cheers.
Cheers.
Crankshaft angles...firing pulses...balancing....and a theory.
Never figured out what the theory was....but someone identified a problem and used a 6 cylinder crank design to solve it.
I remember an 80 degree V8 Indy Chevrolet but, I can't say this is one of those cranks.shoedoos wrote: ↑Thu Nov 28, 2019 1:01 pm First time I have seen one of these, anyone care to educate on their usage pros/cons?
They look like they are for making atrue V4 out of the V8.
GMC truck & buss offered a 60 degree V8 engine from 1966 through 1972 but, it was based upon the 478 cubic inch V6 with two cylinders added.Walter R. Malik wrote: ↑Fri Nov 29, 2019 12:07 amI remember an 80 degree V8 Indy Chevrolet but, I can't say this is one of those cranks.shoedoos wrote: ↑Thu Nov 28, 2019 1:01 pm First time I have seen one of these, anyone care to educate on their usage pros/cons?
It ended up as a 637 cubic inch engine. That stroke was 3.860" though with a 5.125" bore.
I can only imagine that someone maybe built an aluminum SBC based upon this design.
Possibly the same reasoning as the Yamaha cross plane crank on 4 cylinder.
Well, if Gaerte built it they probably had a reason (might have worked, might not). Someone should ask them.
Gaerte is out of business and the assets auctioned, so no help there. Earl passed away years ago.
But they were big in circle track racing, specifically sprint cars. If we go in knowing that, the 3.76" stroke with a 4.155" bore gets us 408 inches, pretty close to a 410 sprinter, with a tad left for an overbore before resleeving it. It sounds like a 72 or 60 degree V8 project. And Brodix made most of the blocks used in sprinters, so it wouldn't be too hard to have them help you out with special projects. Don't know what benefit it would have in a sprinter though.
