440 ci ls engine timing chain
sccagt1racer
Post by sccagt1racer » Thu Nov 28, 2019 4:31 pm
Im building a 440 ci ls engine 12.5 to compression brodex br7 heads with jessel shaft rockers. the open spring pressure is 610. using a comp cams solid 730 lift cam. max rpm 8000. I cant see the factory single roller timing chain being able to handle this kind of abuse. Would a cs 1175 rollmaster chain be the chain to use or is there a better choice. I know a jessel belt drive would be optimal but im not willing to drop 1600 for a chain.
mag2555
Re: 440 ci ls engine timing chain
Post by mag2555 » Fri Nov 29, 2019 6:49 am
If it where me I would glad purge my wallet of the 270 bucks needed to get a Comp Cams duel idler gear drive set up!
CGT
Post by CGT » Fri Nov 29, 2019 8:54 am
Oh yeah except that its gross and not 270.00
https://www.lsxceleration.com/comp-cams ... rive-5495/
Mark Twain
Golf is a good walk spoiled.
Mark Twain
mag2555
Post by mag2555 » Fri Nov 29, 2019 9:40 am
Sorry, I thought he was talking Mopar 440.
