Rod strength
digger
Re: Rod strength
Post by digger »
modok wrote: Thu Dec 05, 2019 8:51 pm A single 1/4-28 bolt can hold 1500 pounds tension, and it has lots of score marks since it's threaded.
The figure of 1500lb is is wrong. it would have to be several times that to even be believable.
Nevermind the threaded holes in the rod which is the same material as the cracked part
It’s probably 1500psi in the cylinder that drives the wedge that splits it
modok
Re: Rod strength
Post by modok »
Yeah, probably
ptuomov
Re: Rod strength
Post by ptuomov »
I'm not an engineer, but I have read somewhere that they use a weight that they drop from some height to break the rods. Perhaps the 1500 lbs refers to the weight but the height is unspecified.
Put Search Keywords Here
Re: Rod strength
Post by MadBill »
Here's one way it's done:
