Can I assume that nitriding steel cams is a different story? And nitriding cast cams needing less agresssive spring pressures would be ok?CamKing wrote: ↑Fri Dec 06, 2019 10:29 amThat's what we use, but it still has to be Nitrided at 850f. The issue is, that the cast iron core is hardened to around 52rc, but when you nitrude it at 850f, it reduces the core hardness of the iron. You end up with a cam that has a very hard outer shell(.001"-.003"), but the material behind that outer shell is now only in the mid 40rc range. With high spring pressures, after a while, the material behind the hard outer shell will give way, and the outer shell will start to flake off.
We offer plasma nitriding on our flat tappet cams, for those that want it, but we don't recommend it.
Nitrided cams
Re: Nitrided cams
Re: Nitrided cams
We have to straiten every cam that comes through the door, except Redline.ProPower engines wrote: ↑Fri Dec 06, 2019 12:28 am I would straighten it but if it snaps its on me. I did not order it for customer it was supplied by him.
I just don't want to chance it on my dime. Better it be dealt with by customer much safer for me that way.
Personally I have always chosen a quality cam over convenience and having to wait long times for a special order.
It always seems the more hands it pass's through more chance there can be an issue.
Re: Nitrided cams
Any time you nitride a material that has been heat treated, if the nitriding temp is higher then the temp used to temper the material, you are going to be drawing back the base hardness of the material.
How much, depends on the material. Say you're plasma nitriding at 850f. If the cam was one of my S7 steel cams, it would draw the base hardness down to about 53hrc. If the cam was made out of 4141, it would be drawn all the way down to about 38hrc.
