Port texture and velocity
When going from a smooth port to a textured port, does the average velocity change?
Re: Port texture and velocity
If the fluid flow is through a straight tube, there is very little change in velocity; a result of boundary layer effects.
If the tube is curved, the air mass will impact the walls and a textured surface will result in a higher friction loss.
Velocity would only change overall if the flow rate has changed.
- Stan Weiss
Chad,
Can you post some before and after cfm and velocity. We can then calculate what change in effective area the air is seeing.
I did this honest hillbilly test.Stan Weiss wrote: ↑Fri Dec 06, 2019 3:33 pm Chad,
http://speierracingheads.com/burr-vs-60-grit.html
Great info Chad, would be interesting, would my iron heads be different such as like seeing bigger gains with the burr?SpeierRacingHeads wrote: ↑Fri Dec 06, 2019 4:44 pmI did this honest hillbilly test.Stan Weiss wrote: ↑Fri Dec 06, 2019 3:33 pm Chad,
www.autotransdesign.com www.gzmotorsports.com
www.cranecams.com www.prosystemsracing.com
www.hardblok.com
Please say a prayer for all that serve and gave all to serve this Holiday and everyday!
www.hardblok.com
Interesting for sure. I may have to do a rethink on some things. The only issue I have is getting the burr finish correct. I can't duplicate what your finish looks like.
i would have expected that the measured averages to be the same if the flow is the same
I would expect the flow rate to be somewhat lower with a textured surface due to an increase in the friction factor.
I'm working with and engine that by rule has a primary header smaller than the exhaust port.My thinking was that texturing the exhaust port would increase velocity thru the center of the port.Because of the small header I'm not using the whole port anyway.
Didn't work , small lose in power over polished port in A-B-A test.
I tried several ideals with poor results .The only thing that shown results is polishing the header till it is so thin that cracking is a problem .
Texture is totally wrong on the exhaust. The FASTER the localized airspeed, the more polished it should be. The SLOWER the localized airspeed, the rougher it should be. Remember, at the wall the air velocity is zero or near zero. The viscosity of the air is holding onto the wall so, the faster the air gets, the thinner the boundary layer gets. Regardless of surface texture. The surface texture is all wet flow any way. IMO around 1% flow loss is attributed to frictional wall drag of the boundary layer.RCJ wrote: ↑Mon Dec 09, 2019 1:58 pm I'm working with and engine that by rule has a primary header smaller than the exhaust port.My thinking was that texturing the exhaust port would increase velocity thru the center of the port.Because of the small header I'm not using the whole port anyway.
The flow numbers were the same though so the average velocity is the same since the area is for all intensive purposes the sameDavid Redszus wrote: ↑Mon Dec 09, 2019 11:56 amI would expect the flow rate to be somewhat lower with a textured surface due to an increase in the friction factor.
Surface texture has an effect on flow coefficient in curved sections at higher velocities. Low pressure ratio measurements are quite inaccurate and should not be trusted for critical work.digger wrote: ↑Mon Dec 09, 2019 3:05 pmThe flow numbers were the same though so the average velocity is the same since the area is for all intensive purposes the sameDavid Redszus wrote: ↑Mon Dec 09, 2019 11:56 amI would expect the flow rate to be somewhat lower with a textured surface due to an increase in the friction factor.
