Dart sbc little m
Dart sbc little m
How many rebuilds do you do before you replace the ARP main cap Bearings bolts. I have two rebuilds on the bolts right now. Motor has 650 hp and spins 7000rpm . I know dart recommends to replace every two or three rebuilds. Thanks in advance
[IMG]http://i44.photobucket.com/albums/f29/fishman1/S7300198-1.jpg[/IMG]
Re: Dart sbc little m
i dont have a answer to your question sorry,
i just purchased a Dart little M and at machine shop at the moment,
i have read some rocker oiling issues,is there any tips or things you have found on the dart blocks
i apologize for the hijack
A couple little things. Might have to tap threaded holes deeper too.
Jim
Yea, the main thing that I remember is tapping the pipe plug holes deeper. De-burr the cam bearing bores and the freeze plug holes. I fact, an overall de-burr is probably necessary.
Steve, be sure to check the lifter bores diameter against the lifters you're going to use. The Dart lifter bores are a bit on the small side (intentionally) for better lifter clearance.steve cowan wrote: ↑Tue Dec 10, 2019 2:44 amI just purchased a Dart little M and at machine shop at the moment,i have read some rocker oiling issues,is there any tips or things you have found on the dart blocks.
